Question about Legacy LA2259 Car Audio Amplifier
Only one channel is puttin out sound and its vary low power i have checked all the connections and they are all hooked up right any idea on what the problem(s) could be?
    Problem Solver:
  • 8 Answers
Try checking the fuses... How Many amps is the fuses u are using ? most of the time it is best to match the fuses with the amplifiers output. check the fuses also to see if any are blown or broken, or the nobs on the amp. there are controls on the amp u set to putout the amount of bass u want and other setting u want your amp to be set at.
Hope this helps.
Posted on Oct 07, 2010
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Is it possible to hook up a powered subwoofer to this unit? It has a centre pre-out, but nothing labelled for a sub, and the manual is useless. This is a very nice old receiver, works perfectly, and I'm...
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSXD903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
(To the guy [dunnbiker] that says there's no rear channels: You're wrong.) The VSX-D903S has 2 stereo (A/B) channels, dual center channel (place center speakers to the left and right, or above and below the screen), and two rear satellite channels. It is a 3-Ch Logic/Dolby Pro-Logic Surround equipped receiver, not a DolbyDigital/DTS multichannel x.1 surround unit.
Dec 19, 2010 | Pioneer VSX-D903S Receiver
Legacy Amp 2600 watt HELP
Hello e_cody_e,
The settings you have will not break anything and may sound OK.
But they may not be optimum for getting the best bass from your system. The SubSonic setting filters out frequencies below the threshold of hearing allowing the amp to put more power into the frequencies that can be heard. So, it should be set to about the same frequency that your enclosure is tuned for or just a little lower. If your enclosure is tuned for 35Hz, then the subsonic should be close to maximum.
Similarily, the low pass sends all frequencies below the setting to the subs, (other than those blocked by the subsonic filter) and is commonly referred to as the "crossover" frequency. Typical crossover frequencies for subwoofers are 60Hz, 80Hz and 100Hz. For a ported enclosure, lower is probably better.
The phase shift should be set to the position that best synchronizes the bass with the music. Because of the additional wiring required for the subs, the signal to them is sometimes slightly delayed causing the bass to be "out-of-sync" with the rest of the music. The thump of the bass comes just a little sooner or later than expected. If the bass sounds out of phase, turn the phase shift on, otherwise leave it off.
The "gain" or level control allows you to match the amps input to your head units subwoofer output. The best setting is usually as high as possible without distortion. Set it by turning up the head unit volume to about 3/4 maximum and then advance the amp gain until your subs just begin to distort. Then back it off slightly.
These settings should allow your amp to put the most power into the frequencies that your subwoofers are designed for and hence produce the loudest and lowest bass.
Hope this helps.
Jun 28, 2009 | Legacy Car Audio & Video
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
No sound
ok i think you might be lucky, i just had this problem for like 2 months.........k with your cd player on, get a multimeter turn it to DC volts, put the black probe on the ground of the amp and touch the red the power or remote, if its under 11 volts you found it....most likely its the fuse right off the battery check it at the far side with the multimeter......hopefully this helps
Jul 07, 2008 | Car Audio & Video
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Legacy LA2259 Car Audio Amplifier Logo
42 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
