Question about Kenmore 24 in. 16019 Built-in Dishwasher
Kenmore dishwasher 16019 will not power on
My dishwasher was in the middle of a cycle and just went off and will not power back on, I have already check all the fuses in our fuse box and they are all fine, have any suggestions as to what it could be?
  • wteturner1 Jun 06, 2008
    We actually already tried that and it worked for about 5 min and went back out apparently blew the fuse again and we dont know what is causing it to blow??? any suggestions?
  • 413 Answers
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
Posted on May 29, 2008
  • Richard
    Richard Jun 06, 2008
    It's possible the heater relay may be stuck. To test for this, temporarily bypass the fuse. Operate the DW for 2 minutes. Open the door and see if the heater is hot. The heater should not be hot, if it is, the control board needs to be replaced. DO NOT CONTINUE TO OPERATE THE DW WITH THE FUSE BYPASSED
Middle wash arm and top wash arm not turning. Water comes out of two outside holes on middle wash arm....
Is it filling with enough water? If not sure dump another gallon of water in there once it stopped filling. If still not working I would take the pump apart and check for excessive blockage anywhere or broken chopper. If everything looks good then you probably need a new motor with impeller.
Sep 24, 2011 | Kenmore 24 in. 16019 Built-in Dishwasher
My kenmore dishwasher will not fill up all the way
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
The clean light flashes 7 times. This started after a power outage.
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
What temperature does this washer reach
It depends on the cycle you choose. Normal wash will bring the temperature to 120 F. Hi Temp Wash will bring it to 140 F. If you choose sani rinse it will maintain at least 155 F for 15 minutes.
Apr 30, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
Will not turn on after stopping in middle of a cycle
Check the following to address this issue--
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 02, 2009 | Kenmore Dishwashers
Kenmore dishwasher
Check the continuity of the thermal fuse (part # 8193762). It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Mar 12, 2009 | Kenmore Dishwashers
KENMORE DISHWASHER
First, turn the unit off at the breaker. Wait 5 minutes. Turn back on. That may reset everything. If not, we need to find out more about the code and what else is going on.
Dec 07, 2007 | Kenmore 24 in. 16019 Built-in Dishwasher
Kenmore 24 in. 16019 Built-in Dishwasher Logo
264 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
