Question about Sylvania 6419TC 19" TV
I want to play my xbox I have da yellow white and red wires plugged in but can't get to the video channel...I know I need a remote but which one?
    President:
  • 1,114 Answers
You would use the Sylvania remote. It will either have a TV/Vid button or an input button. The screen will display "Video" or "Line". You can also do this from the front of the set by pressing "CH-" it will go "3", "2", "Video"
Posted on Oct 07, 2010
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
How do i wire red white and yellow rca to an xbox 1 av plug. my av plug has blaack white orange and green wires
In the old school standard AV: Red and White are usually audio channels (Red:Right - White:Left), Yellow is video.
Orange can be coax audio, (both L&R channels in one cable). Before digital (optical) came out, some receivers actually had a coax (orange) jack in the back. Radio Shack sells a splitter if necessary.
In higher resolution systems video is separated into three colored cables: RGB or Red, Green, Blue
called 'component' video. The green cable carries Yellow, the blue cable carries (PB) Blue and the red cable carries Red (PR). And with today's tech, the component signal is carried YCBCR as (digital video.) cf. http://en.wikipedia.org/wiki/YPbPr
Component 'wire colors' are there just to remind us. If your TV has "Component" input. Try green to green, white to yellow and black to red. Orange to audio (splitting L&R if necessary)..
Also, here is a PS3 link that might help: http://www.ps3hax.net/showthread.php?t=9238
Good luck !
Apr 23, 2011 | Video Game Consoles & Games
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
I have no picture but hear the sound of the system on my tv
It could be 3 things:
Your tv connections are disconnected and need to be replaced. See if anything else works when plugged into these connections.
Your cable cord could have a disconnect internally and the cord needs replaced.
Your graphics card on you XBOX 360 is shot any you need to replace it.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Microsoft Xbox 360 Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
No connection DVD to G25189TK. No external channel set. (3 or 4)
to see the dvd video you should select the AVmode using your TVremote.if the wires are not properly connected you cant see the picture or video.try to connect the wires in the front panel or the back panel.try to connect the wires as per the notes given as audio input,video input etc.
Dec 06, 2008 | RCA G27647 27" TV
How can I be able to program my proscan television model no.( P S 32 108 television ) with out a remote control? to play a DVD player I pluged the wire RED WHITE YELLOW in.The television is set on...
Try changing channels down lower than ch.2 and it should go to a Video channel, or Video1 or Video2, etc. One of those will be for the input where you plugged in the Red/White/Yellow cable.
Or there could just be a TV/Video button on the front of the set.
Aug 08, 2008 | Televison & Video
I have SOUND but no PICTURE
Check the AV plugs those are the red white and yellow plugs make sure that the yellow is plugged into the yellow circle on your tv and red to red and white to white, unless your on hdtv. if there plugged in make sure it is on the right channel probably 3 or 4 if those dont work change it to video mode or input mode.
Dec 25, 2007 | Microsoft Xbox 360 Console
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Sylvania 6419TC 19" TV Logo
105 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
