Only connection to the TV is the power cord and cable wire. I moved the TV and plugged it back in.....no sound !! Checked cable connection and electrical plug in.
    President:
  • 1,114 Answers
Depending on the type of TV that it is, check your "menu" go to "audio" and look for "speakers" on/off or internal/external. if you still have an issue, post a reply with the make and model of the TV and I can pull the manual. Hope this helps.
Posted on Oct 07, 2010
NES controller input
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Mar 02, 2012 | Nintendo NES Console
How do you hook up the super nintindo console to the tv?
Original-Style Super NES RF to TV Hookup
hook_sns_rftotv.gif Installation Steps:
  1. Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
  2. Disconnect the existing cable wire from the TV's VHF IN.
  3. Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
  4. Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
  5. Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
  6. On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
  3. Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
  4. Slide the Power Switch to the On position.
  5. Turn on the TV and set it to the appropriate channel (3 or 4.)
  6. The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 13, 2012 | Nintendo Super NES Console
Eu tava com o super nintendo ligado e ele espludiu a fonte
Aug 21, 2011 | Nintendo Super NES Console
Red vertical line on the screen due to external shock
This is most likely caused by the cable on the T-CON board being bent out of place by the shock.
If you know how to work on electronics or have a friend with knowledge/skill you can fix it.
DO THIS ONLY IF YOU KNOW HOW TO WORK WITH ELECTRONIC EQUIPMENT.
REMOVE THE PLUG FROM THE WALL. REMOVE INPUT signal cable from set.
REMOVE THE POWER CABLE FROM THE SET.
>Lay the set down on a flat cloth covered surface.
>Remove the back cover.
>Remove the shield covering T-CON board. This small board is located in the center near the top.
>Move the cable(s) connected to the T-CON around.
> Set the tv upright and make sure it is stable.
DO NOT TOUCH ANYTHING ON THE BACK
ATTACH INPUT SIGNAL cable to set.
ATTACH THE POWER CORD TO THE SET.
PLUG THE POWER CORD INTO THE WALL.
>Use the remote to turn the set on. If the vertical lines are gone, THEN TURN the set OFF.
REMOVE THE POWER CORD FROM THE SET. Remove signal cable.
> Lay tv back down on table.
CAREFULLY REPLACE THE SHIELD over the T-CON.
Replace the back cover etc.
Now you can reconnect the input cable and power cord.
SOMETIMES THE IMAGES can get worst and you have to repeat moving the cable around. In the worst case you can dis-connect and re-connect the flat cable WITH THE SET UNPLUGGED.
I believe the T-CON may sometimes be called LVDS and look similar to;
Feb 15, 2011 | Sharp Aquos LC52XD1E 52 in. HDTV-Ready LCD...
I put on the tv but it it does not go on. Checked all wires and connections, and all ok.
Tries unplug the tv and the cable box,replug both it back like an hour later.The tv,now will reset itself,back to the factory setting.The tv cable box,will reset itself and upgraded it software.The tv now,should work again.Not,than the tv have problems,with it power supply board.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 03, 2010 | LG 42LC2D 42 in. LCD HDTV
Need to know how to hook up the dinosaur nintendo
Installation Steps:
Jun 05, 2010 | Nintendo NES Console
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Need new power cord
Recommend against soldering the damaged ends together - it's ugly, will never be especially safe, and risks being unreliable too. Have a look at the TV end of the cable. Does it go straight into the TV, or is there a plug that goes into the TV. If there's a plug, just pull it out, take it along to shop that sells TVs and they'll sell you a new one off the shelf. If the cable goes straight into the TV, the solution is just a tiny bit more involved. First, look at the mains plug to check whether it is moulded on, or rewirable. If moulded on, you will need both a new plug, and some flex. If rewireable, you'll only need the flex. Either way, take the cut-off end to Home Depot or somewhere similar and buy something the same shape and size (thickness of the wires is the important thing here). To fit, carefully take the back off the TV and look at how the existing cord was connected and secured before removing it and putting the new one on in exactly the same way. Don't forget to push the wire through the hole in the case (if there is one) before connecting it up. Once the flex is fitted to the TV, fit the plug to the other end. Safety/reliability tip 1 - while the back is off, try not to touch any electrical or electronic components inside the TV other than the power terminals you're supposed to be working on. Saety tip 2 - when renewing a power cord, wire the new cord to the appliance before fitting the plug to the other end of the cord - amazing how many people have helpfully been plugged into the mains in the middle of a job. A.
May 01, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
