Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Leaking water out of bottom of door, thinking it needs to be cleaned, how is that done3
  • 4,345 Answers
The bottom of the door is not actually sealed, look for incorrect soap.
Posted on Oct 07, 2010
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
Leaking dishwasher
Check you gasket around the door for cracks, if needed replace it or clean the door around the bottom and see if it helps.
Oct 16, 2012 | Dishwashers
Water is leaking copiously from the bottom front door.I think the seal has broken.How difficult is it to replace.A repair man cannot even look at it until wednesday next week.
Before you replace it try cleaning the bottom of the glass door. Often water deposits and soap build up on the bottom of the glass door and it no longer makes a good seal with the door boot.
Other wise it's not hard to replace the boot, just take a little time as you will have to remove the front of the washer.
Aug 03, 2011 | Dishwashers
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
Hi Door to my ariston a1600wd is leaking any ideas? I cn't afford to get a technician out, I am willing to try and fix it myself. Is is a seal or a door problem?
Is it definately the door? ive had the water leaking from the top drawer but looked like the door! Ive just cleaned the filter from the drum to the water pump and it was blocked, which makes me think the pump cant pump the water out quick enought on the spin cousing water to rise. U can get to the filter from the rear of the machine by taking the plastic cover off at the bottom and removing the black gater where the filter is inside
May 23, 2010 | Washing Machines
Eurotech Dishwasher is leaking - How to get to the guts to fix it
When a dishwasher leaks, it is usually the door seal or the water level gone wrong. Assuming the door was never leaned-on and the hinges bent, then you look to the seal or in some cases a splashshield fin that goes along the bottom between door and frame. If the unit is more than 7 or 8 years, the seal or shield plate could have lost its shape enough to allow water to get by.
The other problem, is the water level is too hi and this can be because the float switch is filled with soap scum and is heavier than normal, so the float thinks there needs to be more water than usual. Clean the float, you may need to remove a guard shroud to access the float. Goodluck, macgivor
Jan 02, 2010 | EuroTech EDW242C Stainless Steel Built-in...
LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Mar 16, 2009 | LG WM2688H Front Load Washer
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
183 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
