Question about Siemens Computers & Internet
Hi All,, I have a Fjitsu Siemens Amilo Pro V2060,, It`s working fine then screen goes blank,,greenish colour, i switch off, then on again everything fine,, this is periodic,, I have also noticed,, on bottom of lcd, just behind the "fujitsu siemens" badge,, this area is becoming very hot,, any answers,,??.. Thanks in advance
    Sergeant:
  • 458 Answers
Sounds like it is getting too hot. NEVER USE YOUR LAPTOP WITHOUT BEING PROPPED UP. Use a fan to blow on it while it is propped up.
Laptops breath from the bottom. If you leave it flat, it will get too hot. Also check the inside for dust or dog hair. Be very careful taking a laptop apart. Some mnfr sites have step by step directions. Do not take it apart if you are not sure that you can. You might be lucky that it is not damaged because a Pentium will shut down when it gets too hot most of the time.
Rate me if this helps.
Posted on May 29, 2008
Fujitsu Siemens Amilo - Won't boot
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
Where is the second memory slot on the Amilo Li1818 motherboard
hi this is kamal.
pls go through this link so pls open and solve your problem..
http://www.amilo-forum.com/topic,809,-Amilo-Pro-v2060-and-maybe-others-ram-slot-location-guide.html
and pls let me know....
regards
kamal singh
Oct 08, 2009 | Fujitsu Siemens Computers & Internet
Fujitsu Siemens V2060 repair manual please
Try this, but is simple, just open the laptop's cover and carefull remove old fan and put the new one! No soldering needed!
Sep 14, 2009 | Computers & Internet
Cant switch my wireless on
do you have an Fn button(function) the letters Fn are usually a different colour.If so you need to hold it down and then press the wireless button.The wireless button should have the same coloured letters or symbol looks like an aerial
good luck
any prob let me know
Mar 08, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Amilo pro v2055 blank screen
Remove the battery and the power supply. Hook it to wall power only w/o the battery and try to turn it on. If it boots great, otherwise pull the power from the unit while it tries to turn on. Plug it back in and try turning it on again. If that doesn't work you need to re-seat the RAM and/or processor. Last thing to try if that doesn't work is new RAM as a processor almost NEVER goes bad and it is either the RAM or the motherboard at that point.
Nov 10, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Blank screen
Sometimes an easy solution to this is to turn off your laptop completely, remove the power lead from the socket and the laptop, then remove the battery, leave for a couple of minutes and then try again.
If this does not work, then you are into the realms of programming / restoring.
I hope this helps you, Chris
Oct 27, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo xa series
The fan speed is controlled by the processor and BIOS. It is on full speed when it starts, but the processor turns it down again as soon as it starts to run.
Could be loose memory modules or the processor heatsink has come loose. Try taking off the back compartments and check everything is fitted OK.
Jul 27, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Screen going blank on fujitsu siemens amilo L1300
hi
change place og your magnetic device nearly to display if there.
reset your monitor.
degauss it.
also check your cpu display option with other display if u have.
Mar 25, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
FUJITSU SIEMENS AMILO PRO V2000D
Hi
It sounds like Drivers for the Video card is not loaded properly.
What is the current screen resolution?
Are you able to increase the resolution to say 800 x 600 pixel or preferably 1024 x 768 pixel?
If the current screen resolution is 640 x 480 pixel and you are unable to increase resolution to the above pixel levels, try updating Windows Drivers for your video card.
AMILO Pro V2000 Display - Intel® 82852/82855 GM/GME Graphics Controller Family (Intel® 852/855 Chipset Family) (WinXP, W2000) Version: 6.14.10.3792.
Directly download - http://support.fujitsu-siemens.com/download/ShowDescription.asp?SoftwareGUID=325da0bd-fe5f-41e6-84d9-d628c5411188&OSID=665F4A20-6E31-43C3-82C2-D98CE773007C&Status=True&Component=Intel%20855GM
Regards
Mike
Mar 18, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
FUJITSU SIEMENS AMILO PRO V200D
Hi
Regards
Mike
Computers & Internet Logo
122 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
