Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Brissells won't spend - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Oct 07, 2010
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
My Kirby G3 diamond series won't turn on
Hi There, The most common problem by far is that the cord is faulty. This is a pretty easy repair to do at home. If your machine was randomly cutting out before it stopped altogether then the cord is likely the culprit. If however it stopped all of a sudden with no warning then it is possibly a switch or motor issue which is a much harder repair to achieve for a novice.
The kirby cords are not terribly expensive (and I have linked a how to video showing how its done) so if you need a new one I would say DIY is the go, otherwise spend the $25 get a pro to take a look.
May 22, 2012 | Kirby Generation 3 Bagged Upright Vacuum
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
Our Bissell Proheat Carept Cleaner 1699 is not dispensing any soap; only weater is running thru the cleaner. We are using the Bissel cleaning soap, not an off brand. Any suggestions would be appreciated?...
Hi Paul,
I just want to make sure that you still would like help with your Bissell. As you may see from my profile, when I help someone out, I always spend considerable time answering questions, taking pictures, and really making sure that you know how to fix the problem. Before I spend so much time doing this, I like to follow up and make sure that A. there's a real customer I'm answering, and B. that you haven't already fixed your machine. If you'd like me to walk you through this troubleshooting, please just add a comment here on the repair page.
Thanks,
Chris Jones
Apr 11, 2010 | Bissell 1699 ProHeat Clear View Upright...
Hoover U8147-900 WindTunnel V2 Bagless Upright has sparks coming from motor housing
Most bagless uprights are exposed to dirt being drawn through their motors and filtered afterwards. As a result when you see sparks the motor has generally suffered its final breath... Today's uprights often run with high RPM disposable motors where older bag type uprights used lower speed rebuildable motors.
So the short answer is you likely need an entire motor as a minimum. If the unit is a higher end model mover $200 , in great condition and less than 5 years old, take it to a Hoover service center and either buy and install a motor or have them rebuild it. But also consider this...
What most people don't realize is they spend more on high priced consumable filters for many cheap bagless vacs than they ever would spend on bags and in the end the bagless is dirty to handle and has a shorter life span. Mass merchants sell the vacs cheap because their profit is in the filters
Remember a vacuum is the hardest working appliance in your home in the toughest possible conditions
If you replace this vac do so at a pro shop and see the options they have. You will get good advice , you will spend a bit more with better results and less frustration because you will build a relationship .....and always know where to go for service.
Oct 08, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
