Question about Toshiba Televison & Video
Toshiba TV volume just going up by itself.What could be the problem?
  • 4,340 Answers
Look for rogue remotes, and remotes under sofa cushions
Posted on Oct 07, 2010
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
Volume on my Toshiba TV 32AV502U goes up on its own at random times. Remote brings the volume down but within minutes volume goes up again. Solution??
First off, take the batteries out of your remote to see if it is a problem with your remote, if it is I would buy a new universal remote and try that. If none of this works then the problem is with your tv itself. Either the volume button on the tv is broken and works on its own, or the tv is having programming errors and you will need to have it fixed.
Jun 26, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
Will my virgin hd tv remot control be able to oporate the volume through its own amp or will i need to adust the volume with the toshiba tv remote on the tv itself
The easiest way is just to set the TV Volume with its own remote at the maximum level you'd want it and then use your Virgin remote to adjust the volume as and when required.
Jun 05, 2011 | Toshiba Televison & Video
The volume on my toshiba 32AV502U TV is constantly going up on its own, ive checked the sensor by covering it and ive only recently discovered its the volume button. it fixed itself after 2 weeks and then...
i have had the same problem with tv.what i did is taped the volume up button on the tv a little hard and it has seemed to fix it for now.as of 1-12-2011 if it does not stay then i will disconnect the wires going to the volume switch.the switch is defective not the remote.
Dec 24, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Televison & Video Logo
153 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
