Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Need a wick and battery pack for a TOYOSTOVE KSA-105, where can i find these?
  • 674 Answers
Hardware stores usually carry wicks. One brand is Kero World. Wick #503K works for the KSA-105. I have one that I bought and the person never brought their heater by so I could replace the wick. The battery pack could be ordered through a Toyostove dealer.
Posted on Oct 08, 2010
Service centre in Dammam KSA
http://www.bing.com/search?q=Dammam+KSA+pc+repair&qs=n&form=QBRE&pq=dammam+ksa+pc+repair&sc=0-12&sp=-1&sk=&cvid=24e46eba47994ac8b0bc0e6ce59d678a Dammam KSA pc repair Bing
Apr 06, 2015 | Computers & Internet
How do i replace the wick in the omni 105 heater
It differs slightly depending on which model type you have. You have to check your serial number and whatever the last letter is, that is your model type. Then go here for the Owners Manual:
ToyotomiUSA Owners Manuals
Inside will be the instructions for changing the wick for your model type.
Dec 23, 2014 | Heating & Cooling
How do you replace just the top part of the wick on a comfort glow GR9B kerosene heater?
    • Remove the base plate from your Comfort Glow heater and expose the fuel tank. Lift the fuel tank out of the heater and set it to one side, well away from the heater. Note that the fuel tank is not connected to anything and will slide out easily.
    • 2 Run the heater until all the fuel in the lines is used, a process called "dry burnicon1.png," which usually only takes a few minutes. The fire will go out when the lines are empty. Turn the heater switch off and allow it to cool.
    • 3 Take the batteries out of the battery compartment on the back of the heater. This is an important safetyicon1.png step that keeps the heater from accidentally coming on while you are working on it.
    • 4 Lift the wick ring up and off, then remove the two nuts that secure the wick. The wick ring fits around the wick and the draft pipe -- the hollow tube that holds the wick -- and serves to hold the wick firmly in place.
    • 5 Slide the wick up as far as possible to reveal the positioning pin -- the small metal pin near the bottom of the wick. This pin is part of the wick and helpsicon1.png to ensure it is installed correctly. Push it out through the positioning hole in the draft pipe and lift the wick out of the heater.
    • 6 Fit the new wick onto the draft pipe and engage the positioning pin in the hole by pushing it in until it clicks into place. Move the wick down into the heater and replace the two nuts to secure it.
    • 7 Measure the distance between the wick and the draft pipe with the clearance gauge. The distance between the wick and the draft pipe should be the same all the way around, to ensure an even burn. Adjust the set screws as necessary to create even spacing. These are the small screws spaced evenly around the draft pipe that, when turned, move the pipe slightly so you can correct the spacing between the draft pipe and the wick.
    • 8 Replace the wick ring over the wick. Return the batteries to the battery compartment and the fuel tank to its compartment. The fuel tank will slide securely into its compartment in only one way. Replace the fuel compartment cover to complete the project.
Tips & Warnings
  • Keep the heater set on medium to medium-high for best results. Setting it too low or too high may cause soot to accumulate on the wick.
  • When operating a kerosene heater indoors, always have a working carbon monoxide alarm and a smoke alarm. These heaters are generally safe when in use, but an alarm will provide a safety backup in case the heater malfunctions
Oct 14, 2013 | Northern Tool 10,600 BTU Radiant Kerosene...
BATTERY SIZE AA OR AAA
Neither. The SD1300 / IXUS 105 uses the NB-6L lithium-ion rechargeable pack.
Sep 13, 2012 | Canon PowerShot SD1300 IS IXUS 105...
Need new battery and I have a NiMH battery replacement. Can I use it on my phone? I have model number 25838GE6-A.
NiMH is a universal replacement battery. It will work in place of nicad and other types of rechargeable batteries, and will work with virtually any charger
Dec 22, 2009 | Uniden Cordless Phone
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Battery for pyramid 105
If you are able to give some information about the battery, i can tel you where to get it. They are generally available. :)
Apr 23, 2008 | Audio Players & Recorders
Electric starter
I have a different make and model, but many of these use a similar design. A battery pack (2 x D or C cell) is mounted on the kerosine tank. The batteries are used to heat a coil. The coil is pressed by an external button against the heater wick. Pressing the button also engages the switch, heating the coil until it glows red hot.
1. Open the burner chamber of the unit and confirm it has a wick installed (this is a used heater--who knows it's condition). Close the chamber.
2. Make sure the tip-over protection hasn't retracted the wick. Generally the tip-over protection is reset by a lever on the base of the burner.
3. Adjust the wick all the way up. A knob on the base of the burner does this.
4. Fully depress the electric starter until the coil touches the wick.
5. When the kerosine on the wick ignites, release the starter and adjust the wick to the desired level.
If the electric start coil does not glow, check the batteries. If the batteries are good, the starter coil may be bad. These are also
replaceable.
Nov 08, 2007 | Corona 23-DK Compact Heater
Toyostove Laser 56 (F type) making loud humming noise
the toyostove is basically a glorified monitor heater.  its components are a combustion blower, an air circulator fan, a flame pot, a flat wick or burner mat, a solenoid pump, an ignition element, double  walled intake, exhaust pipe.   the combustion blower is a glorified vacuum cleaner motor. it sucks in cool air and channels it to the combustion chamber along the sides (round cylinder) kero enters on the burner mat where it ignites. the solenoid pump keeps adding kero until the flame detector spots or heats up. air flow to the pot is regulated by a damper in the combustion air blower line. if the "O" ring in the damper is missing or hardened it will not regulate the air flow which is necessary for combustion.  replace this "O" ring should take care of your problem.
Oct 17, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
165 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
