Question about Lexmark Office Equipment & Supplies
My lexmark printer prints a few lines properly, and then it misses the next few lines, or only partially prints them. How do I correct this problem?
    Brigadier General:
  • 10,406 Answers
On your inkjet printer, start the Lexmark software,
and run a "print-head-cleaning-cycle", since some (not all)
of the ink-jets that shoot the ink onto the paper are CLOGGED.
Posted on Oct 07, 2010
I have a lexmark x4270 printer- black ink cartridge # 71 when printing the words are only partially printed the cartridge is a year old but was unopened until now I tried soaking in warm soapy water no...
unplug the power cord from the outlet and wait 3 or 4 minutes.
Plug it back in and choose the alignment program.
a sheet of paper will print out a series of lines and etc.
once finished , the printer cartridge is alligned properly and will print nice and clear.
Mar 31, 2011 | Lexmark X4270 All-In-One Printer
Lexmark Z615 inkjet printer - whetther I print in colour or black and white, I am getting whole lines of text/image missing. When I use the "clean nozzle" function some of the colours - like...
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
Jan 30, 2011 | Lexmark Z615 InkJet Printer
My mp mP830 prints some lines (or partial lines) Consistantly misses the same rows each page
Sounds like the ink is running out at the same time each printing. Check the ink supply. The printer may not be letting you know the correct amount remaining. It could also be the ink jets themselves getting clogged and not distributing the ink enough to compensate for the amount of printing ink, on the page, in time to print all of it in succession. Do a test of no printing except where it seems to be missing and just print that area (print: selection).
Sep 16, 2010 | Office Equipment & Supplies
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Printing does not work
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Lexmark JetPrinter Z12 color InkJet
I replaced an ink catrage on my Lexmark Z33 printer and it does not print propertly. It will print some lines on the page properly, but some it skips a line and part of another line and then prints the...
I have an Epson w/c had this problem a # of times. Go to the printer PROPERTIES tab (right click printer icon might work). Click on UTILITIES & you should see options for NOZZLE CHECK, HEAD CLEANING & PRINT HEAD ALIGNMENT. Follow instructions on all 3 until your Print Head Alignment printout is perfect. It might take a few head cleaning procedures
before you get it right. Good luck.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Ink replacement has not helped print
Sounds like a damaged or dirty flex cable to the print heads. If those tiny contacts go bad, nothing will print properly. Check the cartridge and socket area for any dirt or dis-coloration. The connections can be cleaned with contact cleaner (from radio shack), and then dried with isopropl alcohol (use the purest you can find).
Jan 03, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Sep 12, 2007 | Lexmark X73 All-In-One InkJet Printer
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
