Question about PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner
How do you scan directly to PC using the USB cable? Can't seem to get it to work other than to memory card.
  • 4,336 Answers
The PC needs to have the control software installed, go to Pandigital and get their install program. Follow install directions exactly, often NOT plug and play or no go...
Posted on Oct 07, 2010
When i try to scan picture on the Canon Pixma MG6150, i get a message saying "set the PC to start scanning". i dont know what that means
You need to install and set up the Canon MP Navigator EX (if available for your OS) in order for the computer to "hear" and launch the scan program. This only works for USB connected printers; a bad USB cable could break the feature. Try a different cable (no longer than 6' long) and a direct connection if you are using a USB hub. The software doesn't correctly respond to the buttons when the MG6150 is a networked printer. http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG6150.aspx?type=download&page=1 lists all of the software available. Use the drop-down menus to limit the list. I found it at the bottom of the second page of files for Vista drivers and software in English.
Next launch the Navigator program and manually start a scan. Then use that scan to give you the defaults for future scans. To launch scans from the scan to computer button on the scanner. Go to Preferences and the Scanner Button Settings Tab. Set an Event as Save to PC and then Scan Type to Auto Scan. Set additional settings based on the manual scan.
If you are using the all-in-one as a networked printer, you can scan manually by launching the software from the computer or scan to a memory card or USB drive from the control panel on the printer. See the Canon support page (Scan to memory card or USB drive) for details. Start here: http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG6150.aspx?faqtcmuri=tcm:13-776471&page=1&type=faq .
If the MP Navigator isn't available for your OS, try Windows Fax and Scan for Windows 7 and 8. Look for a similar program on the Mac or Unix systems. Then you will need to do the manual scan as above.
I hope this helps.
Jun 18, 2013 | Office Equipment & Supplies
I need help my laptop is not letting me download my pictures from my pny premium 4gb memory card .. it does work on my camera
How did u try to download pics? What i know is that there are two ways to save something from a memory card to a PC. One way is via USB cable and other way is directly from mem card.
If you're trying to save your pics from CAM to PC using an USB cable and not working at all then try opening up the memory card from your CAM and insert the card directly into your laptop in the laptop's memory card slot but if there isnt any slot, try to get it into a card reader and then attach the card reader with your PC. Hope it will work for you, best of luck.... x
<Zulkernine from Bangladesh>
Sep 14, 2012 | PNY 4GB Premium Secure Digital High...
I lost password of my scan disk memory card.So i cant connect it to pc.How to recover it.
You'll need to format your memory card by plugging it directly onto your computer. Thats the only way to use it Im afraid.
Cheers.
Mar 20, 2011 | SanDisk 2GB microSD Memory Card
Hi, I have problems with downloading pictures from my Canon PowerShot 200IS. The PC is not recognizing the camera any more (used to work before). It doesn't work using the UBS-cable nor insering the...
I hope its usb cable my have some problem..... try to purchase a new car reader to insert memory card into it and plug it to pc via usb port..... then also if you face same problem then check you usb port drives and install them......... to rectify this problem.... some times firewall also will not accept usb so switch off firewalls while plug in device cable........
Oct 17, 2010 | Canon PowerShot SX 200 IS Digital Camera
My mmc memory card currepted
First: better use kasperaskey anti virus.
If your desktop PC or laptop has anti virus,
have your PC scan your memory card through blue tooth, or usb cable.
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
Take care.
Oct 13, 2010 | Nokia 3230 Cellular Phone
How do I put my photos onto my laptop
You have 3 options;
  1. Data Cable
  2. USB Bluetooth Dongle or a PC with in-built Bluetooth
  3. Memory Card Reader
With a data cable you can transfer the content direct to your PC, all you would need is a Data Cable (obviously) and the appropriate USB Cable Drivers for your phone which can usually be found on the SE website.
With a USB Bluetooth Dongle or a PC with in-built Bluetooth you can transfer the content direct to your PC and you don't need the USB Cable drivers for your SE phone.
With a Memory Card Reader you can simply plug the reader into your PC, copy the content to the appropriate folder on your Memory Card, then put the Memory Card back in your phone.
May 22, 2010 | Sony Ericsson W380i Cellular Phone
Memory card error message
I suspect this is the result of the printer not seeing the computer properly, it sounds like it is assuming you have no other data source so wants the memory card to pull from. Check the USB cable between the printer and your computer for a loose connection. Try unplugging and plugging in the USB cable and power supply. You also could try connecting the USB cable to another port.
If that doesn't work, it may be that the driver was updated by something and now isn't working as well with your system. Reinstall the software program that came with the HP Photosmart C4180. To do this in Windows, uninstall the old program through the "Add/Remove Programs" menu. Insert the CD-ROM that came with the printer and follow the on-screen instructions to complete the reinstallation.
Aug 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
After downloading my images from my memory card to pc with my Samsung UGH-600 my memory card no longer works in my phone when I press my files - memory card it freezes
Did you insert the memory card in the right direction? Well, I would suggest you to try to reformat your memory card then insert it on your phone. Next time try to use the USB cable tp connect it to your pc.
Jul 27, 2009 | Samsung SGH-G600 Cellular Phone
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Pc does not read images from memory card
Install a USB card reader and use that
Mar 15, 2017 | Cameras
PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner Logo
678 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
