Question about Westinghouse Refrigerators
Westinghouse fridge/freezer (freezer on top) has suddenly stopped working (purchased December 2003). I can still hear something running (motor?!), any suggestions please?
  • Westinghouse Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 07, 2010
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
My Westinghouse Rp241T fridge is not getting cold. I can hear the motor running but it isn't cold. The fridge isn't very old and I suspect the thermostat?? Where is it located or am I off the...
Hi, Sounds like there was/is a leak in the refrigerant system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Aug 31, 2011 | Refrigerators
Hi, Have a Westinghouse Fridge/Freezer BJ414BQ-RWZ, approx 14 years old. Has recently not keeping cool enough. Looking for tips on what I can do to correct. Tried turning a white knob on rear/base of...
heatman101
Jun 04, 2011 | Westinghouse Refrigerators
Fridge at the top is not working, freeer at the bottom is working perfectly. Our fridge has stopped working, all lights are on inside. We have turned the power off and then back on again. It is only 4...
All cooling takes place in the freezer (bottom, in your case). Freezer air must be circulated into the fresh food compartment to cool it. There is a fan in the freezer called the evaporator fan, which is supposed to do this job.
1. You have a blockage in the return vent to the freezer. Remove item that is on the floor of the fresh food section and find this return vent (hole or passageway) and prove to yourself that it is clear.
2. Freezer fan is not working. You should hear it when opening the freezer door. Some units shut opff when the door is open, so see if pushing the button that turns off the freezer light does that too. If not working find out why. Fan blade stuck on something? Motor seized? Replace failed motor.
3. Defrost system has failed, allowing ice build-up on the evaporator (behind freezer back wall). Test heater, defrost limiting thermostat, and defrost timer circuit. If a circuit board determines defrost cycle timing, replace it if the def. thermostat and heater are good.
Jan 29, 2011 | Westinghouse Refrigerators
My Westinghouse Fridge just suddenly stopped cooling and freezing. The motor still runs, but its not doing anything.
The most probable thing is that the compressor has quit and is not moving the gas around that cools it.You can actyually hear the compressor turn on and off you pull out the fridge and listen to it. The compressor is the metal tank at the bottom it may be warm but one of the tubes coming out of it should be cold if it is working properly. Also it could have leaked out all the gas but not likely to happen.
I would say it could be the thermostat but there is a seperate one for the freezer and the fridge and the chances of both of them quittin at the same time is very unusual.
Oct 07, 2010 | Refrigerators
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
424 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
