Question about OTC Ball Joint Installer / Remover
Can not figure out how to install my lower ball joint
  • 4,336 Answers
There are special tools and procedures and it is VERY EASY to get hurt, if you do not understand suspensions. You did not specify make, model or year, so there are tons of possibilities.... But consider having a shop do this and remain uninjured.
Posted on Oct 07, 2010
How do i replce ball joints on a 99 pontiac sufire
Lower Control Arm Ball Joint Replacement Removal Procedure Tools Required J 43828 Ball Joint Separator
  1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  2. Remove the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  3. Remove the stabilizer shaft link. Refer to Stabilizer Shaft Link Replacement .
  4. Remove the wiring harness from the lower control arm.
  6. Remove the cotter pin (1) from the ball joint (3).
  7. Remove the nut (4) from the ball joint (3).
    Notice: Use only the recommended tools for separating the ball joint from the knuckle. Failure to use the recommended tools may cause damage to the ball joint and seal.
  9. Remove the ball joint from the steering knuckle using the J 43828 .
  11. Remove the lower control arm front (1) and rear (4) mounting bolts.
  12. Remove the lower control arm (1) from the vehicle and place in a vice.
  13. Drill out the 3 rivets (3) retaining the ball joint to the lower control arm (2).
  14. Use a 3 mm (1/8 in) drill bit in order to make a pilot hole through the rivets.
    Finish drilling the rivets with a 13 mm (½ in) drill bit.
  15. Remove the ball joint (4) from the control arm (2).
Installation Procedure
  1. Install the ball joint (4) into the control arm (2).
  2. Install the 3 ball joint bolts (3) and the nuts (1). Follow the instructions in the ball joint kit. Tighten the ball joint bolts (3) according to the specifications in the instructions.
  4. Install the lower control arm (2) to the front suspension support (1)
  5. Notice: Refer to Fastener Notice in the Preface section.
  6. Install the lower control arm front (5) and rear (4) mounting bolts.
  7. Tighten • Tighten the front bolt to 107 N·m (79 lb ft). • Tighten the rear bolt to 110 N·m (81 lb ft).
  8. Install the lower ball joint stud (3) to the steering knuckle (2).
  9. Install the ball joint stud (3) through the steering knuckle (2).
  10. Install the ball joint nut (4).
  11. Tighten
    Tighten the ball joint nut to 55 N·m (41 lb ft) plus 180 degree rotation minimum-65 N·m (50 lb ft) plus 180 degree rotation maximum to install the cotter pin.
  12. Install the wiring harness to the lower control arm.
  13. Install the cotter pin (1).
  14. Install the stabilizer link to the lower control arm. Refer to Stabilizer Shaft Link Replacement .
  15. Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  16. Inspect the front wheel alignment. Refer to Wheel Alignment Specifications in Wheel Alignment.
Sep 15, 2011 | 2003 Pontiac Sunfire
How to replace a lower ball joint on 2004 mercury mountaineer?
Remove the brake caliper by removing the two bolts that connect it to the steering knuckle. Remove the lower ball joint cotter pin and retaining nut. Pry the steering knuckle up and away from the lower ball joint. Unscrew the grease fitting from the bottom of the lower control arm. Press the lower ball joint out of the control arm using a ball joint remover set.
Press the lower ball joint into the control arm using a ball joint installation tool. Remove the block of wood supporting the upper control arm. Install a new cotter pin through the ball joint stud.Install the grease fitting on the bottom of the ball joint. Use a c-clamp to push the piston back into the brake caliper. Reinstall the wheel assembly. Here you can find the quality parts http://www.buyautoparts.com/steering_system.htm
Aug 29, 2011 | Mercury Mountaineer Cars & Trucks
Ball joint repair and how do you do it
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
  1. Using a screw driver or other suitable tool, pry the seal boot off of the ball joint assembly
  2. Position receiving cup, Special Tool 6758 to support lower control arm when removing ball joint assembly. Install Remover, Special Tool 6919 on the top of the ball joint assembly.
  3. Using the arbor press, press the ball joint assembly completely out of the lower control arm.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
  1. By hand, position ball joint into ball joint bore of lower control arm. Be sure ball joint is not cocked in the bore of the control arm, this will cause the ball joint to bind when being pressed into control arm.
  1. Position control arm with installed ball joint, in an arbor press with Receiving Cup, Special Tool 6758 supporting the lower control arm. Then center Installer, Special Tool 6908-4 on the bottom of the ball joint
  2. Carefully align all pieces. Then press the ball joint into the lower control arm until it is completely seated against surface of lower control arm. The ball joint is correctly installed when there is no gap between the ball joint and the lower control arm. Do not apply excessive force against the ball joint or the lower control arm.
  3. Install a NEW seal boot by hand as far as possible on the ball joint. Installation of the seal boot is to be with the shield positioned as shown.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
  1. Place Installer, Special Tool 6758 over seal boot and squarely align it with bottom edge of seal boot. Apply hand pressure to Special Tool 6758 until seal boot is pressed squarely against top surface of lower control arm.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
  1. Reinstall lower control arm on vehicle.
Mar 07, 2011 | 2000 Dodge Caravan
Replace lower ball joints. How do you replace Lower ball jonits?
REMOVAL & INSTALLATION
  1. Raise and safely support the vehicle, allowing the front suspension to hang free.
  2. Remove the wheel and tire assembly. WARNING
    Be careful when working in the area of the CV-joint boot. Damage to the boot could result in eventual CV-joint failure. If necessary, install CV-joint boot protector tool J-34754 or equivalent, to protect the boot.
  3. On Eldorado and Seville with 4.6L engine, remove the road sensing suspension position sensor from the lower control arm.
  4. Remove the cotter pin and nut from the ball joint stud. Use ball joint separator tool J-36226 or equivalent, on Deville and Fleetwood or ball joint separator tool J-35315 or equivalent, on Eldorado and Seville, to separate the ball joint from the steering knuckle.
  5. On Deville and Fleetwood, loosen the stabilizer bar link nut.
    1. Drill out the 3 rivets retaining the ball joint to the lower control arm and remove the ball joint. NOTE: Recommended drill-bit is 1⁄2 inch (13 mm). Fig. 1: Drilling the rivets out of the lower control arm 91048g05.gif
      Fig. 2: Installing the bolts in the lower control arm 91048g06.gif
      To install:
  6. Attach the new ball joint to the lower control arm with 3 mounting bolts and nuts.
    1. On Deville and Fleetwood, the bolts must be installed from the top of the control arm.
    2. On Eldorado and Seville, the bolts must be installed from the bottom of the control arm
    3. Tighten the nuts to 50 ft. lbs. (68 Nm).
    4. On Catera, the bolts must be installed from the top of the control arm.
    5. Tighten the nuts to 26 ft. lbs. (35 Nm).
  7. On Deville and Fleetwood, tighten the stabilizer bar link nut to 13 ft. lbs. (17 Nm).
  8. Connect the ball joint to the steering knuckle and install the castellated nut.
  9. On Deville and Fleetwood, tighten the ball joint nut to 88 inch lbs. (10 Nm). Then tighten the nut an additional 120°, during which a tighten of 41 ft. lbs. (55 Nm) must be obtained.
  10. On Eldorado and Seville, tighten the ball joint nut to 84 inch lbs. (10 Nm). Then tighten the nut an additional 120°, during which a minimum torque of 37 ft. lbs. (50 Nm) must be obtained. If the minimum torque is not obtained, check for stripped threads. If the threads are okay, replace the ball joint and knuckle.
  11. On Catera, tighten the pinch bolt to 74 ft. lb. (100 Nm).
  12. Install a new cotter pin. If the cotter pin cannot be installed because the hole in the stud does not align with a nut castellation, tighten the nut up to an additional 60°to allow for installation. NEVER loosen the nut to provide for cotter pin installation.
  13. On Eldorado and Seville with 4.6L engine, install the road sensing suspension position sensor to the lower control arm.
  14. If necessary, remove the CV-joint boot protector tool.
  15. Install the wheel and tire assembly and lower the vehicle. Fig. 3: Separating the ball joint from the steering knuckle 84208016.gif
    Fig. 4: Lower ball joint installation - Deville and Fleetwood 84208017.gif
    Fig. 5: Lower ball joint installation - Eldorado and Seville 84208018.gif
Jan 17, 2011 | 1991 Cadillac DeVille
How to replace a lower ball joint on a 1988 pontiac grand prix hit a pothole and it popped out
Hope this helps and please don't forget to rate! Thank you!
Front ball joint with heat shield
Remove and Replace-
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle with jackstands.
  3. Remove the front wheel and tire assembly.
  4. Unfasten the retaining bolts, then remove the ball joint heat shield.
  5. Remove and discard the lower ball joint cotter pin.
  6. Remove the ball joint nut.
  7. Loosen, but do NOT remove, the stabilizer shaft bushing assembly bolts.
  8. Separate the ball joint from the strut/knuckle assembly using ball joint/tie rod puller J-35917 or equivalent.
Do NOT damage the halfshaft boots when drilling out the ball joint rivets.
  1. Drill out the rivets retaining the ball joint to the knuckle strut assembly and remove the ball joint from the knuckle. Use a 1/8 in. drill bit. Refer to the instructions in the ball joint replacement kit.
To install:
  1. Position the lower ball joint in the strut/knuckle assembly.
  2. Install the four ball joint bolts and nuts, as shown in the ball joint kit and tighten to specifications.
  3. Install the ball joint-to-lower control arm. Install a new ball joint-to-lower control arm nut.
  4. Tighten the stabilizer shaft bolts to 35 ft. lbs. (48 Nm).
  5. For 1988-91 vehicles, tighten the ball joint-to-lower control arm nut 15 ft. lbs. (20 Nm) plus at least an additional 90° (11/2flats), plus enough to align the cotter pin hole. Do NOT overtighten.
  6. For 1992-96 vehicles, tighten the lower ball joint nut to 63 ft. lbs. (85 Nm). Tighten to align the next slot in the nut with the cotter pin hole in the stud. Do NOT tighten more than 60° (1 flat) to align with the hole.
  7. Install a new cotter pin.
  8. Position the ball joint heat shield and secure with the retaining bolts. Tighten to 62 inch lbs. (7 Nm).
  9. Install the front wheel and tire assembly, then carefully lower the vehicle.
  10. Connect the negative battery cable and check for proper suspension operation
Apr 26, 2010 | 1988 Pontiac Grand Prix
How do you put in a ball joint in a 2001 sebring convertible
It depends on exactly which ball joint of the 3 per side your changing, but here are the details.
COMPRESSION LOWER ARM & LATERAL LOWER ARM ASSEMBLIES
Removal
1. Loosen compression lower arm ball joint nut. Using steering linkage puller, separate ball joint and
knuckle. Remove nut, bolts and compression lower arm assembly. Remove dust cover.
2. Remove stay. Remove shock absorber lower mounting bolt. Loosen lateral lower arm ball
joint and knuckle nut. Using steering linkage puller, separate ball joint and knuckle. Remove nut, bolt and
lateral lower arm assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for compression lower arm ball joint is 4-22 INCH lbs. (0.5-2.5
N.m) for 2000 models. On 2001 models, breakaway torque is 22-54 INCH lbs. (2.5-6.1 N.m). Ensure
breakaway torque for compression lateral lower arm ball joint is 13 INCH lbs. (1.5 N.m). Check compression
lower arm, lateral lower arm, dust covers, and bushings for damage and wear.
Installation
To install, reverse removal procedure. Use NEW ball joint nuts. Lubricate lip and inside of dust cover with
multipurpose lubricant. Using installer, install dust cover. Check front wheel alignment.
UPPER ARM ASSEMBLY
Removal
Using steering linkage puller, loosen upper arm ball joint and knuckle nut. Remove self-locking nut. Remove upper arm and upper arm shaft assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for upper arm ball joint is 3-13 INCH lbs. (0.3-1.5 N.m).
Replace upper arm assembly when measured value exceeds specification. Check upper arm, dust cover, and
Installation
1. To install, reverse removal procedure. Use NEW self-locking nuts. Lubricate lip and inside of dust cover
with multipurpose lubricant. Using Ball Joint Installer (MB990800), install dust cover.
2. Ensure upper arm shaft assembly is installed at indicated angle. Verify upper arm shaft
assembly installation. Check front wheel alignment.
Once you have the correct arm off and a replacement joint (if available, some are not serviceable and require the arm to be replaced) then you will need a press or a ball joint press to change the joint. Such as
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46389
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66958
or http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46967
Mar 17, 2010 | 2002 Chrysler Sebring
How to replace lower left front ball joint ?
Removal & Installation NOTE This procedure requires the use of the following special tools: J 9519-E Lower Ball Joint Remover and Installer, J 34874 Booster Seal Remover/Installer, J 41435 Ball Joint Installer, J 45105-1 Ball Joint Flaring Adapter and J 45105-2 Receiver.
  1. On 4WD vehicles, remove the wheel center cap and drive axle nut.
  2. Raise and support the vehicle.
  3. Remove or disconnect the following:
    • Tire and wheel
    • Wheel hub and bearing, if necessary
    • Outer tie rod retaining nut
    • Out tie rod from the steering knuckle using a suitable puller
    • Brake hose bracket retaining bolts and bracket
    • Upper control arm-to-steering knuckle pinch bolt and nut
    • Upper control arm from the steering knuckle
    • Lower ball joint retaining nut
    • Steering knuckle from the lower control arm using a suitable ball joint removal tool
    • Steering knuckle from the vehicle
    • Lower ball joint flange with a chisel
  4. Install tools J 9519-E and J 34874 to the lower ball joint, then use those tools to remove the lower ball joint from the lower control arm.
To install:
  1. Install or connect the following:
    • Lower ball joint to the lower control arm, using tools J 9519-E, J 41435 and J 45105-2
  2. Remove the tools from the lower control arm.
    • Tools J 9519-E and J 45105-1 to the lower ball joint
  3. Flare the lower ball joint flange with J 9519-E and J 45105-1, then remove the tools from the lower ball joint.
    • Steering knuckle to the lower control arm
    • Lower ball joint retaining nut and tighten to 81 ft. lbs. (110 Nm)
    • Upper control arm to the steering knuckle
    • Upper control arm pinch bolt and nut and tighten to 30 ft. lbs. (41 Nm)
    • Brake hose bracket to the steering knuckle
    • Brake hose bracket retaining nuts and tighten to 7 ft. lbs. (10 Nm)
    • Outer tie rod to the steering knuckle
    • Outer tie rod retaining nut and tighten to 33 ft. lbs. (45 Nm)
    • Wheel hub and bearing, if removed
    • Tire and wheel
  4. Lower the vehicle
    • Drive axle nut, if 4WD, and tighten to 103 ft. lbs. (140 Nm)
    • Wheel center cap, if removed
  5. Check the front wheel alignment.
Nov 30, 2009 | 2002 Oldsmobile Bravada
I cant seem to remove the ball joint on my 96
the lower joints are pressed into the lower arm from the bottom, and they are in TIGHT, try suppporting the control arm under the spring mount and banging it out with a heavy hammer or at least loosten it a bit, the new one must be pressed in, make sure it goes in even all the way the lip must be flush, grind the rivets from the upper and install the new one with bolts supplied, its a lot of work for a diy
Nov 26, 2009 | 1995 Buick Roadmaster
Replace ball joints
Remove in this order: wheel, loosen the 4 lower ball joint set bolts, cotter pin and nut from tie rod, tie rod from ball joint bracket, ball joint from lower control arm, 4 lower ball joint set bolts, ball joint from suspension. Install is reverse but don't tighten the 4 lower ball joint set bolts.
torque is as follows:
ball joint to control arm- 112 ft-lbs
Tie rod nut- 67 ft-lbs
lower ball joint set bolts- 83 ft-lbs
remember to use a new cotter pin
Oct 08, 2008 | 2004 Toyota Tacoma
Lower ball joint removal how to
  1. Remove the steering knuckle with wheel hub and bearing attached.
  2. Remove the lower ball joint flange with a chisel.
  3. Install J9519-E and J34874 to the lower ball joint.
  4. Remove the lower ball joint from the lower control arm using J9519-E and J34874
  1. Install the lower ball joint and J9519-E, J41435, and J45105-2 to the lower control arm.
  2. Install the lower ball joint to the lower control arm using J9519-E, J41435, and J45105-2.
  3. Remove J9519-E, J41435, and J45105-2 from the lower control arm
    1. Install J9519-E and J45105-1 to the lower ball joint.
    2. Flare the lower ball joint flange using J9519-E and J45105-1.
    3. Remove J9519-E and J45105-1 from the lower ball joint.
    4. Install the steering knuckle with wheel hub and bearing attached. Install the tire and wheel.
    1. Lower the vehicle.
    2. Check the front wheel alignment.
these jouints are pressed in and there is a flange that is flared this is what the tool numbers refer too.
Sep 12, 2008 | 2002 Chevrolet TrailBlazer
OTC Ball Joint Installer / Remover Logo
52 people viewed this question
Top OTC Tools & Hardware - Others Experts
Are you an OTC Tool and Hardware - Other Expert? Answer questions, earn points and help others
