Question about Car Audio & Video
2000 s type 4.0 liter jaguar. Has been in a creek. water mid way up doors. WHat is likely to be shorted and /or burnt out? Where do I start? John
  • 1 more comment
  • jv_flanagan Oct 07, 2010
    Hi Geekman,
    Seems there is some mistake. I thought I was asking a general question in the cars and auto section about a car that has been in a flood. It appears that I am in the wrong area. Speakers I can fix (or throw out) its the ECU's that I need to know about
    Cheers
    John
    Thanks, can the ecu be cleaned? I have taken the cover off and there is mold on the back of the PCB. Is it more likely that the components have "burnt out" rather than just a short which when removed would let the unit operate?
    I do have an OBD11 tool but wanted to inspect and clean some obvious problems first. It was fresh water by the way.
    Thanks Mate, I have already started and I have a second car with good electrics and a bad motor. 2 = 1 I am hoping.
    I have undone and cleaned and checked all connections etc. Yes it may take a couple of days but I'll get there in the end. I have used WD40 to clean the verdigris off the circuit board and plug connectors.
    Thanks for your help
    President:
  • 4,070 Answers
Hi! As a first course of action I strongly suggest that you remove the battery connectors. Just let it seat for a few days till everything is dried up. After that you may install it and check for possible problems. Please do write back on the progress. Hope this helps and have a good one!
Posted on Oct 07, 2010
  • 6,826 Answers
If the doors have the speakers, then the speakers could be dirty from the creek water. Having the connectors shorting out the amplifiers in the radio can be possible anytime water gets into the speaker area.
May need another radio and clean up the wire connections to the speaker.
Are you having a nonfunctioning radio right now?
  • Car Audio & ... Master
  • 32,281 Answers
Speakers do not like being wet. Depending upon how long they have been submerged and how they have been dried out, I would guess they are permanently damaged.
The only way to test the speakers, is to remove the speakers and examine them and test them on the bench with a working amp.
The voice coil on the speaker could be stuck or corroded against the magnet. The speaker diaphragm could be broken. this means the speakers needs to be replaced.
I suggest the radio/amp be check out first to see if it functions properly.
  • Chris Hingee
    Chris Hingee Oct 07, 2010
    It is highly likely the ECU is shorted out, especially if the unit was powered up when it was in the water. The ECU is a computer, and other electronic sensors may also be damaged.
    There is an electronic diagnostic unit that plugs into the data connector of the ECU that downloads the error log to identify the faults, provided the ECU is still functioning.
  • Chris Hingee
    My guess, components are burnt out, but I would try to clean and dry the ECU out, and then try the ECU out. You might be lucky, you have nothing to lose.
    Bear in mind the wiring and connectors to sensors as wells as the sensors themselves etc. could give you problems, it might take you a while to trace these faults.
    I hope you have a service manual with the circuit diagrams.
    Good luck, I think this will not be a quick and easy job.
2000 jaguar s/type easiest way to accest blend door 4.0 liter
a common problem on this model is the servo motors/potentiometers that drive the flaps go faulty there was a jaguar mod/recall which involved changing all of them sounds like 1 off the servos as give up remove the lower dash liners and check connectors etcthe blend flap is high up on the lh side
Dec 18, 2016 | Jaguar Cars & Trucks
Fail safe engine mode mean in a 2000 jaguar s type?
Hi Walter, the fail safe mode is for getting you home when something goes wrong and you need to move the vehicle a short distance. If it is engaged you should take the vehicle for a scan and find out what is wrong. Regards John
Nov 02, 2011 | 2000 Jaguar S-Type
Where is the fuse box on my jaguar s type sport,year 2000
On all the s-type's I've had you have three places for fuse box's. One under hood, one in trunk, and one on the passenger side wall forward the door under the glove box. The passenger side one will have most of your simple fuse's for light's, radio, cig liter etc...
Sep 08, 2011 | 2000 Jaguar S-Type
Hola necesito el orden de encendido de un Jaguar 2000 motor 4.0 V8 gracias
2000 Jaguar 4.0 liter DOHC V-8 (AJ28)
2000 Jaguar 4.0 liter SC DOHC V-8 (AJ27)
Espero que esto le sea de ayuda (recuerde calificar esta respuesta).
Feb 22, 2011 | 2000 Jaguar S-Type
WHAT IS THE FIRING ORDER FOR JAGUAR S TYPES 2000
Here are the firing order diagrams for the 3.0 liter V-6 and the 4.0 liter V-8 engines.
2000 S-Type 3.0 liter V-6
2000 S-Type 4.0 liter V-8
Jun 18, 2010 | 2000 Jaguar S-Type
2000 jaguar type s battery is dead after not driving car for 2 days
One possible cause is water in the boot well. It seeps into the wiring loom and shorts. This would drain the battery. If this is the problem, dry out the well and keep it dry.
Mar 06, 2010 | 2000 Jaguar S-Type
Oem motor oil 2000 s type
2000 JAGUAR S-TYPE 3.0L 6-cyl Engine Code [F] DOHC
5W-30 America / 5W-40 European due to higher speed limits
Engine, with filter..........5.7 liters / Models from VIN code L31321 to L37177 year coverage 2000 to 2002.5
Engine, with filter..........6.5 liters / Models from VIN code L37178 to M45254 year coverage 2000 to 2002.5
2000 JAGUAR S-TYPE 4.0L 8-cyl Engine Code [G] DOHC
After refill check oil level, and hope this helps.
Dec 13, 2009 | 2000 Jaguar S-Type
I need firing order diagram on a 2000 S-Type Jaguar- V-8, 4 liter, 6 cylinder
2000 4.0 jaguar s type cylinder firing diagram:
FRONT OF CAR
5 1
6 2
7 3
8 4
Sep 09, 2009 | 2000 Jaguar S-Type
Stuck in water at the creek flooded everything now wont run
start draining fluids before the gears and brgs rust
Jul 11, 2009 | 1999 Chevrolet Blazer
My 2002 s type jaguar won't heat, only blows cold air
Hi
Sounds like your heater water control flow valve is not operating, and stuck on closed, cold position.
Hope this has been of help.
Good Luck
John.
Jan 16, 2009 | 2000 Jaguar S-Type
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
