SAYS INK CARTRIDGE PRBLEM - Office Equipment & Supplies
  • 386 Answers
Hi Good day!! Check your Ink Cartridge if it is properly inserted.. or just take out the cartridge and put it back make sure it is inserted properly.. and see if the error still there
Posted on Oct 07, 2010
How do I fix printer prblem
Depends on your printer really. Firstly have you properly followed the instructions before loading the cartridges? With most you need to pull off a tab covering the ink outlet. That is on the assumption that the printer is new or this is the first time you have changed cartridges.
Some printers won't print if one cartridge is empty but the others are full.
It is also possible that the printer has stalled because the print queue stalled when the ink ran out.
Access and clear the print queue. Restart both computer and printer.
Other than that impossible to say until you identify the printer - but most have a diagnostic mode.
Dec 08, 2014 | Kodak Esp-3 Easyshare All In One Printer
I recently purchased a MX850 Cannon Pixma printer. After a month of low volume usage there seems to be a prblem with the printer head. I only use cannon ink but for some reason the ink is smearing and...
I replaced the printer head on this after trying to clean it by running water through it. Since then I have only had to do the maintenance cleaning when the printer "skips". I bought an "R-JetTek" cartridge re-filler and use bulk ink with a cartridge re-setter with no problems for going on 3 years now.
Apr 14, 2017 | Canon Office Equipment & Supplies
How will i insert the ink cartridge?
i think this video can help you to solve your prblem
Jan 04, 2011 | Canon PIXMA iP1300 Printer
Hello, my problem is, when i print a copy I receive a blank line, it seems like the ink is finish or the middle of the ink is finish or don't have ink. don't know what to do I tried to clean the toners and...
If you are seeing a white line down the page in one or more areas, but it is printing fine in others it is most likely your toner or your drum. Try taking the toner cartridge out and shaking from side to side to evenly distribute the toner and break up any lumps that might have formed while it sat around. If that doesn't work take out your drum unit and look at the drum roller (don't touch it!) if you see lines or color differences on it then it might need to be replaced.
Aug 18, 2010 | HP LaserJet CP1515n Printer
Printer shows i have half full ink,but when i print it prints very light and half way down page there is nothing?
i think there is a prblem about the ink cartridge. the noozle maybe it doesnt flow the ink or maybe you filled the cartridge too much of ink. try a new cartridge cartridge but before that try to clean the noozle of your ink cartridge.. - **wanski cebu**
Oct 11, 2009 | HP DeskJet 3745 Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
PGI5BK Ink tank not recognized on MP600
You say the "original" is 3 months old? You are out of ink. Replace the cartridge. Even when there is still a little ink in the "tank" it reports back to the printer as empty. And yes it will go through all its checks and still show empty. They don't last forever even if you don't use the printer. The ink evaporates out over time.
Nov 21, 2007 | Canon Pixma MP800 All-In-One InkJet...
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
216 people viewed this question
k24674
jasbo
jasbo
