Question about D-Link DI-704P Router
Vista Compatibility with DI-704P
Is there a Vista version of the print server or if there isn't are there 'work arounds'. Thanks in advance.
  • 1 more comment
  • merekat17 Jun 02, 2008
    I also am unable to install the print server software under Windows Vista. I have no problems running the print server software under Windows XP, despite it not being listed in the manual as a supported OS.
    I tried setting the compatibility mode to Windows 2000 on the setup.exe under the NT folder, but it did not seem to make a difference. Like I have found with most software that I run under Vista that is older, a lot of times you have to wait 15 minutes or so for the first or second dialog box to finally pop up.
  • gleesonc Aug 10, 2008
    I have a PC plugged into a DI-704P router and it prints through it to a Canon laserprinter. I now also wish to plug my new laptop into the router and print to the same laserprinter. Tried your suggestions on configuring a port but can't get it to happen. Any suggestions?
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    The print server is not be designed for a specific operating system. The DP-704P can be used with Windows, Mac and Linux. It is your printer driver that needs to be compatible with Vista.
    What are your trying to do? What is the exact problem? With more details about your problem we should be able to help you.
The print server software does not need to be installed in order to print to the printer attached to the 704P from Vista. I went out to D-LINK's website and there are step-by-step instructions for configuring port 192.168.0.1 and associating a printer with that port.
See the following link:
http://support.dlink.com/faq/print.asp?productid=794
These instructions are for 2000/XP but they are very similiar to what you need to do for Windows Vista. I tried it and it worked fine. It did take me several tries however, as I should have read through the steps completely first.
Posted on Jun 04, 2008
The manual for the D-Link DI-704P will not download. The error message says the file is damaged.
Try this, (click here) this should work, there are many manuals available for this model. If you need further help, let me know.
Good luck.
Thanks for using FixYa
Sep 20, 2010 | D-Link DI-704P Router
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
I use the D-Link DI-704p router for an ethernet Lan with 8 Macs. Fast in the morning, horribly slow up/downloads in afternoon. Output runs at half speed of input from provider when tested in afternoon.
access your router with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi advanced then check signal channel type 4 , 6, 11 are working fine try 1 by 1 theses channel then check.
Set channel which give most high speed.
When you set channel always save settings then restart computer and router both after save settings then check.
Thanks for using fixya.
Jul 28, 2009 | D-Link DI-704P Router
D-link DI-704P lost CD
http://support.dlink.com/products/revision.asp
go here select your version and download everything you need
May 02, 2009 | D-Link DI-704P Router
Will this print server work with windows vista?
- Kindly visit the Motorola support site to check weather your Print Server can able to work with Vista or not.
Mar 13, 2009 | Arris WPS870G (51272300100) Print Server
Problem D-Link DI-704P
then configuration problem then re-configure it check ip addresss, dns value, firewall, proxy server any antivirus is on then off it. some they also create a problem
Mar 09, 2009 | D-Link DI-704P Router
Mac Support for DLink 704P Router
The DI 704 P software is not distributed anymore , as D-Link discontinued the product.
Among 704 P only last version (revision D) supported mac, check here to find out your version.
You can still couple the server to mac using this procedure, give it a try.
If it does not work contact D-Link and ask if you can have copy of control software.
May 28, 2008 | D-Link DI-704P Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
D-Link DI-704P Router Logo
945 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
