Question about Proview PL 866s (Gray, Silver) 18 in. Flat Panel LCD Monitor
I have a proview lcd monitor model pl866s .What is the size of the power connector for the 19vdc @3068a psu?I have an extra psu with the correct voltage /current .Thanks Robert.
    Genius:
  • 1,354 Answers
For the above LCD Monitor, I actually saw a small spark at the top part of the main board once the power input jack was connected. It prompted me to the exact location and when I check the SMD ceramic capacitor (that generated the spark underneath it) with analog meter set to X 10 K ohm range; it actually developed a slight short circuit. Replacing only the fuse and the SMD ceramic capacitor solved the no power problem in this 19" LCD Monitor. This Monitor uses the inverter IC (OZ960G), A1084-25CM (2.5 volts voltage regulator), AMC1117-3.3 (3.3 volts voltage regulator), ADC IC (MST8136B) and CPU IC (MYSON MTV312MV64).
Posted on Oct 07, 2010
On smaller Proview monitor, model 468, there is not power cord.
On the Proview 468 and possibly the PL-456s and the PZ-456if you look at the end of the VGA chord that you connect to the back of the computer right in between the two screws is a power connector for a 12 volt power supply this is for the 468 I hope this helps with your dilemma on how it gets power. tjbraya@yahoo.com
Feb 11, 2012 | Relisys RLT1720 17" LCD Monitor
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
Where can I buy a power cord for my Proview PL456s 14 in. Flat Panel LCD Monitor?
Can you supply a picture of the connection on the back of the monitor? Try to make it high quality and put a scale, ruler or dime near the connector to give proper scale/size and I will research it for you.
Dec 01, 2010 | Proview PL456s 14" Flat Panel LCD Monitor
White screen comes on when powered on
**Caution. Hazardous voltages inside.
This could be a loose connector inside the monitor connecting the LCD panel. A careful check of these delicate connectors (open, reinsert the cable, close the connector) or remove and reconnect the plugs may fix it. White screen means there is no drive to the LCD panel AT ALL.
Mar 30, 2010 | Proview PL926WBi 19" LCD Monitor
Need power cord for CM2017 Balance monitor 19Vdc 3A , connector is one single post Nothing comes up online, no one has heard of Balance Brand
As a workaround, simply get yourself a switchmode power supply that has the spec's 19 V DC @ 3 Amps, now, carefully cut of the end of the "Old" Power Jack, and the end off the "New" power jack, and Join up the wires, usually the "Inner" one is Positive, +, and the "Outer", or shield, is Usually negative, -, If you have a meter this should be used to check, connections. Otherwise just ensure you are correct. That should get you going, even if you cannot find an original, in fact, you may even find, that the PSU, you get has "Multi-way" changeable ends.
Feb 26, 2010 | Balance CM2017 17" Monitor
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Power cord for the Proview Model 800
http://www.cablestogo.com/product_list.asp?cat_id=1024
http://cgi.ebay.com/AC-Adapter%2fAdaptor-Power-Cord-For-PROVIEW-LCD-Monitor_W0QQitemZ150338552665QQcmdZViewItem
Aug 26, 2009 | Proview Computers & Internet
Preview 700 P
you should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Oct 25, 2008 | Proview XL370B (Black) 17 in. Flat Panel...
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Proview PL 866s (Gray, Silver) 18 in. Flat Panel LCD Monitor Logo
154 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
