Question about Sentry FIRE-SAFE Combination Safe DS3431, DS3431
Sequence of turns - Sentry FIRE-SAFE Combination Safe DS3431, DS3431
    Problem Solver:
  • 15 Answers
Heating elements keep coming on and off after blower turns off
Yes your sequencer is the switch to energize the elements & sometime the low speed on the blower motor. It completes the 240 volts going to the elements. The sequencer turns the elements on in stages as well as the blower, & most sequencers have numbers on the side to tell what thermal disk turns on first. The blower, & one element should be wired on the 1 & 2 terminals (this turns on first when the sequencer coil is energized & shuts off last when the coil is de-energized). If any of the thermal discs are stuck closed, this will constantly energize the element on that switch.
Dec 04, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Vulcan ducted heating
Do a continuity test on the heating elements, and if they're good then do the same on the sequencers or contactors, whichever you have. The sequencers (or if you have contactors turn on the heating elements). All the fan does is blow air. It blows against the heating element to put out hot air. Either your sequencers/contactor or your heating element is defective.Wait,each sequencers is connected to a fuse.Check the sequencer fuse too. Find the sequencer/contactor wherever the wire feeding the heating element is coming from.
Aug 20, 2013 | Heating & Cooling
Cylinder head bolt tightening sequence for isuzu rodeo 1998
1998 Isuzu Truck Rodeo 2WD 2.2L MFI DOHC 4cyl
The Head Bolt Torque
Torque sequence ----------------- front ' 7 3 1 5 9 ' of ' ' engine ' 8 4 2 6 10 ' ----------------- Step 1: torque bolts in sequence to 18 Ft/Lbs Step 2: turn bolts in sequence an additional 90-degrees Step 3: turn bolts in sequence an additional 90-degrees Step 4: turn bolts in sequence an additional 90-degrees recheck final torque in sequence
1998 Isuzu Truck Rodeo 2WD 3.2L MFI DOHC 6cyl
Torque sequence -------------- front ' 6 1 3 7 ' of ' ' engine ' 5 2 4 8 ' -------------- Step 1: torque to 20 Ft/Lbs Step 2: torque to 47 Ft/Lbs recheck final torque in sequence
Jan 15, 2013 | 1990 Isuzu Spacecab
Torque settings on a ford ranger 2004 head gasket
Torque sequence ------------ front ' 6 4 2 8 ' ' 5 1 3 7 ' ------------ Step 1: torque in sequence to 59 Ft/Lbs Step 2: loosen all bolts in sequence (1) full turn Step 3: torque in sequence to 40 Ft/Lbs Step 4: torque in sequence to 73 Ft/Lbs recheck final torque in sequence
Mar 24, 2012 | 2004 Ford Ranger
Electric furnace will not turn off
Your sequencer is stuck. A sequencer uses a small coil to warm up the switch so that it will turn the electrical elements on one at a time instead of all at once. If they all come on at once the amp draw would throw the breaker. It is also desired to have warm air come out of the vents when the fan comes on. So how do they do it? With a sequencer:
A sequencer can have up to 4 stacks depending on the amount of coils are in the heater. Each coil on average has a value of 5000 watts. So what ya want to do is turn on a coil then after 30 seconds another coil then after 30 more seconds the fan and maybe another coil depending on your furnace size.
So in your case what is wrong? The sequencer bimetal disc inside it is jammed in the on position and therefore the heater stays on until you tun the breaker off. Replace the sequencer and party on!
Here is a page on sequencers that also features rewiring of an electric furnace
Oct 28, 2011 | Heating & Cooling
Can't find cylinder head torques!!! please advice....
Torque sequence: ----------------- there are two rows of fasteners and you need to start with the middle 2 fasteners first and then work your way toward the front and back in steps. Step 1: torque head bolts #1,2,3,4,5,6,7, & 9 in sequence to 10 Ft/Lbs Step 2: torque head bolts #1,2,3,4,5,6,7, & 9 in sequence to 20 Ft/Lbs Step 3: torque head bolts #1,2,3,4,5,6,7, & 9 in sequence to 29 Ft/Lbs Step 4: turn all head bolts in sequence an additional 90 degrees Step 5: turn all head bolts in sequence an additional 90-degrees recheck final torque in sequence. Fasteners are supposed to be replaced if they are removed since they are torque-to-yeild fasteners.
7 - 5 - 1 - 3 - 10
front
9 - 4 - 2 - 6 - 8
Apr 17, 2011 | 1997 Toyota Previa
Need torque specs for 1994 ford escort 1.9 ltr head bolts
Torque new cylinder head bolts in sequence to 44 ft lb. Loosen bolts approximately two turns, then torque bolts in sequence to 44 ft lb. Turn bolts an additional 90 degrees in sequence, then an additional 90 degrees
Torque sequence
9 3 1 5 7
8 6 2 4 10
May 07, 2010 | 1994 Ford Escort
Need to know what to tighten head bolts to on 1992 saturn sl1
DOHC - Tighten all bolts in sequence to 22 ft. lbs. (30 N.m). Then tighten all bolts to 37 ft. lbs. (50 N.m). Repeat sequence, tightening all bolts an additional 1/4 turn (90 degrees).
SOHC - Tighten all bolts in sequence to 22 ft. lbs. (30 N.m). Then tighten all bolts to 33 ft. lbs. (45 N.m). Repeat sequence, tightening all bolts an additional 1/4 turn (90 degrees).
Torque Sequences
Jan 26, 2010 | 1992 Saturn SL1
Chevy 5.7 17 bolt heads tork specs
Cylinder Head Bolt (Preferred Method) All Bolts First Pass in Sequence 22 ft.lb Long Bolt Final Pass in Sequence 75 deg. Medium Bolt Final Pass in Sequence 65 deg Short Bolt Final Pass in Sequence 55 deg. Cylinder Head Bolt (Optional On-Vehicle Strategy) First Pass in Sequence 26 ft.lb Second Pass in Sequence 44 ft.lb Final Pass in Sequence 66 ft.lb
Oct 13, 2008 | 1999 Chevrolet C1500
Sentry FIRE-SAFE Combination Safe DS3431, DS3431 Logo
113 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
