Question about Senco FP620 Framepro 602 2" - 3 - 1/2" Full Round Head Nailer
Air escapes from gun when i connect to compressor
  • 4,340 Answers
Well, something is amok, you have to take it apart and repair what you find.
Posted on Oct 07, 2010
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
Hitachi framing nail gun, fires ok on a large tank shop compressor but on a portable compressor it continually blows air from the piston. The gun has a new o ring kit from a repair shop. They can't find...
the compressor is not putting enough air into the guns cylinder and the escaping air is a safety feature for safety. You need to get a larger comp or increase the pressure coming out of hose. there should be a gauge on comp. Set it for suggested pressure for each separate tool. Be Safe!
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Jul 22, 2014 | Hitachi NR83AA3 Pneumatic Frame Nail Gun 3...
Product NR83A2. Lubricate is coming from the trigger and exhaust cover. The nailer is new and I put lubricate in the gun prior to placing the air plug on. What is the best way to drain the excess...
Excess oil will eventually be consumed /blown out of gun, however if you store the gun over-nite with air inlet pointed down, gravity will assist. I find that oil /water will accumulate inside gun especially if compressor is passing oil and/or weather conditions cause system to produce lots of water. Majority of guns that come in for repair suffer from a lack of lubrication. Several drops at start of day should be ok for oil lubricated compressors and maybe more for oil-less. If oil drips out of gun overnight (if stored as stated above) then reduce drops. What actually shortens life of gun is debris that enters gun from handling and that enters hoses during transport. Before connecting air hose to gun (with hose under pressure) momentarily connect a spare quick connect fitting and blow debris out of hose.
Mar 16, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
I have three nailers from CH and all of them sound like there is not enough pressure to fire the nail when i depress the trigger. i hear air escape, but it is at a reduced level compared to normal...
Check and adjust the air pressure at the compressor. All air tools have a recommended range of pressure, and you may not have enough air for the tool to work. Also, place two drops of pneumatic oil or light machine oil into the air inlet at the nailer, and then connect the hose. Fire the gun several times into scrap wood. Oil with 2 drops daily.
Best regards, --W/D--
Mar 06, 2011 | Campbell Hausfeld Air Brad...
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Gun stopped driving nails, air escapes from top,
has the gun been cleaned and oiled, i think not.
take the head bolts out of the top of the gun. make sure you pay attention to how everything comes out so you can put it back together.
shake the gun upside down so that the piston comes out. wipe everything down with any petroleum based cleaning solvent to remove all the gunk and reassemble.
pour about 10 dropsof oil down the air input, let it sit there about 5 mins and hook up the air and it should work
Sep 23, 2009 | Tools & Hardware - Others
Water separator not doing it job
If your water separator is not doing the job then you have too much moisture in the compressor tank. Turn on the air relief valve to release the air. Be sure it is at a low point so that the moisture in the tank will also escape. Once the tank is completely empty screw the relief valve shut, start the compressor and then check the output for moisture. You should be good to go.
Hugh
Jan 04, 2009 | Air Tools & Compressors
Air escapeing through triger assembly
The problem that you are describing usually occurs when fine scratches in the head allow air pressure to bypass the orings. Here are a couple of simple tests. Remove the trigger from the gun to give access to the trigger valve plunger. Remove the nails from the gun. While pointing the gun away from you, connect the air supply. There should be no air leaks. Now quickly depress the trigger pin all the way in. This must be done with a very rapidly movement. If the gun fires, then the safety foot is not pushing the trigger pin all the way in. Check for worn trigger or safety mech. When the safety foot is depressed against the work, the trigger pin should be depressed all the way into the trigger valve for the gun to fire. Hold the trigger closed tightly and very firmly depress the gun against the work, the gun should fire. If it does not fire try next test. Remove the head from the gun. Hold it in your hand and depress the headvalve all the way into the head with you thumb. While holding the headvalve in, place a finger over the small venthole on the mating surface of the head and release the headvalve. Vacuum should hold the headvalve in the head for a moment until you release the vent hole. If the headvalve springs back with finger over venthole you must remove the headvalve and inspect the surfaces with maginfing lens for fine scratches. Remove scratches with very fine paper to obtain smooth polished surface. Lube surface with silicone lube (looks like vaseline, sold in small container at Lowes plumbing department used for lubing faucet orings ) re-assemble gun and make sure that you tighten headbolts firmly. You should be ready to work. Good Luck!
Jan 01, 2009 | Air Tools & Compressors
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Senco FP620 Framepro 602 2" - 3 - 1/2" Full Round Head Nailer Logo
211 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
