Question about Maytag Dryers
My maytag gas dryer won't heat , already change the 2 coil, still no heat, pls help
  • 176 Answers
Check the heater element
Posted on Oct 07, 2010
Gas dryer won't heat
check to see if it heats up for the first 2 minutes if it does then i would replace the coils on the valve if not check the thermal fuse on the blower housing
Feb 24, 2013 | Maytag Neptune MCG8000AW Gas Dryer
Dryer works but won't heat up
i had a maytag gas dryer that did this and it was an easy fix. small part called "gas coil"
If it's gas dryer that may be the issue.
Dec 02, 2011 | Dryers
Maytag gas dryer. Heating element comes on however, not every time does the gas click on so I get heat. Gas line is fine. What causes the click that gets you heat for dryer?
That would be the "igniter" you hear. You may have a problem with the igniter or the 2 coils on the gas valve. Below are links to the parts.
Igniter
Coils
Nov 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heats up when cycle is first started, then after a few minutes there is no heat, can you help?
I have a MDG6700 with the same issue..all my research on this problem points to the 2 coils on the gas valve. Tomorrow i am going to change them (kit is about 30 bucks to get local)..coils test good but other postings about this dryer say one coil gets hot and is weak and close the gas valve thus stopping the heating process
Aug 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Neptune MDG5500AW that is not drying. It sometimes has heat but most of the time it does not. Can you help me diagnose the problem?
if it has heat the first 15 to 30 minutes and then no heat you have bad gas coils,they are located on the top of the gas valve,just remove the two phillips screws,remove the cover and change out the coils,
Aug 04, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Flame wont stay on
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 26, 2010 | Maytag SDG3606A Gas Dryer
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
Maytag Neptune mdg6400aww heats up for 1-2 mintutes then not heat
Make sure there are no major airflow obstructions. If not, replace the coil packs on the gas valve.
Aug 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
