Question about Edison DHE55 Dehumidifier
I have an edison 55 dehumidifier that i purchased used . i couldnt tell if it was broke and have no instructions but it has very easy controls so its not complicated at all .turn it on and go . well i did that and after a few hours chcked it for water collection and found that it had been running but the coils on the rear of the machine had frosted over and no water was collected just frost buildup on thse coils . the machine looked like it was in near new shape ,but apparently not . what could it be and can it be fixed by myself,as they are expensive to buy new and i tried to save a buck . thank you so much
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
Illeagle
  • 525 Answers
SOURCE: Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
SOURCE: Edison 25 dehumidifier coils frosting
Same problem with mine.I've tried to clean mine as well. HELP, I live in a very woodsy area and constantly fight humidy.
adrianam@wpa.net
Posted on Jul 13, 2008
  • 104 Answers
SOURCE: dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Posted on Oct 04, 2008
Our model JA2M193N Edison dehumidifier runs but doesn't produce water, the coils get cold, but the fan doesn't come on. What do we need to do to fix it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 14, 2011 | Edison 40 Pint Dehumidifier
I have a edison model dhe40s that freezes the coils and doesn't drip into bucket what could be wrong?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Aug 01, 2011 | Edison 40 Pint Dehumidifier
Need manufacturer n&a or amp draw for Edison dehumidifier dhe25wg
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Edison 40 Pint Dehumidifier
My Edison Dehumidifier does not draw any water. Everything is working great. Model: HDHE405, Type: D40, S/N 14393261 HM
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 22, 2010 | Edison 40 Pint Dehumidifier
Its an edison model emd40s year 200403 and the
Any float will work. Go to home depot and get a toilet float kit. -Good Luck Ned-
Sep 16, 2009 | Edison 40 Pint Dehumidifier
Edison 40 fan runs, sounds like compressor keeps clicking on & off and lights dim
Threw the d--- thing out the door and bought a new one, not an Edison!!
Jun 11, 2008 | Edison 40 Pint Dehumidifier
adrianam@wpa.net
May 12, 2008 | Edison 40 Pint Dehumidifier
Edison 40 Dehumidifier
Old post, but in case someone stumbles in here like i did, I need to point out that if an A/C needs to be recharged, then there has to be a leak somewhere, there is no use on recharging unless you find the place where is leaking.
Jun 01, 2007 | Edison 40 Pint Dehumidifier
Edison DHE55 Dehumidifier Logo
32 people viewed this question
Top Edison Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Daryl Gleaton
Are you an Edison Dehumidifier Expert? Answer questions, earn points and help others
