Question about Polaroid FLM-323B Television
Hi i have fla-323b it will not turn on but the light on the mother board is on the fuse is ok would it be z9 thank you ab
    Problem Solver:
  • 15 Answers
Can you get daylight on it? It sounds like the backlight is not working; if you can get some daylight on the screen when there should be a picture, can you see (very very very faintly) and picture there?
You use daylight as it has some distinct light polarisation and so the lcd's twisting affects the light and you can see if the LCD is ok or not.
If the backlight bulb is gone then it needs replacing; quite costly I'm afraid.
Posted on Oct 07, 2010
Toyota Pasoo ABS light is not turning off. Hi, i have recently bought Toyota Pasoo 2007 (reconditioned japan) and now its ABS light is not turning off even i have checked the break oil level which shows...
The ABS light will not set because of fluid level the red brake light will. Usually an ABS light is set because either the solenoid is faulty, BCM (Body control module) is not functioning properly(not to likely) or there is excessive wear to the brake pads. Solenoid and or BCM can be simply one of the ABS Fuse's. There is one in the engine compartment fuse box and one in the fuse box contained withinor below the dash panel on the drivers side.
Aug 23, 2012 | Cars & Trucks
My gateway m460e wont charge or turn on there are no lights the mother board is dead.what cause this?
Assuming the charger is ok and the battery is ok, you may have a main motherboard fuse which has blown (would explain the lack of power), if the fuse is not the issue, then it looks like there are other damaged components on the board
Jan 10, 2011 | Gateway M460 Notebook
FLM 323B HAVE SOUND BUT NO PICTURE. SCREEN IS
backligth has no power check the inverter board for any open fusable resistor or open fuse and cold solder
Feb 10, 2010 | Polaroid FLM-323B Television
TV has power, the blue light is on but no pic. All the caps look good and i've already replaced the Z9 diod. Help me please.
Hold a flash light on an angle to the screen see if you can see the picture in the backgroung. If you can bad inverter.
Nov 17, 2009 | Polaroid FLM-323B Television
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
Polaroid FLM-323B nothing at all
Check and replace ALL high value electrolytic capacitors on the power supply board. The Polaroids have known issues with leaky caps in the power supply. It's best to just change them all to prevent future failures.
Nov 10, 2008 | Polaroid FLM-323B Television
Poloroid 32 inch FML-323B
Are you sure the two capacitors are not swollen on top?
Sep 21, 2008 | Polaroid FLM-323B Television
Polaroid FLM-323B Will not turn on
Polaroid FLM-323b No power,No led light, checked the fused and the fuse is good?
Can't find any bad Caps? Well I spent some time, well alot of time trying to figure out what's wrong and finally did.
The problem is a diode on the power board location Z9 Part # ( P6KE350A )On some boards it's the diode and the capacitor right next to it part # ( R 331K 1KV )
If this works Please donate Paypal Is12ok@aol.com anything helps Ive spent well over a weeks time and count less hours trying to figure out what was wrong.I have included some pics to try and help.
Thanks Z28r2fast4uc144496.jpg18b1844.jpg27931f3.jpgdb4f9c3.jpg f53556c.jpg 7eeee7c.jpg
Oct 21, 2007 | Polaroid FLM-323B Television
Polaroid FLM-323B Television Logo
50 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
