Question about Whirlpool GSC9455 Top Load Washer
I have a 7-8 year old catalyst washer and it just all of the sudden stopped, it has the lights on, it filled with water but just makes a click sound when its time to wash, but nothing happens??? Please help!!
  • 1 more comment
  • genevafwilli Oct 08, 2010
    OK MY WASHER FILLED UP WITH WATER, AND EVEDRYTHING IS LIT UP AND THE TIMER IS ON, THE WASH SIGN IS LIT, BUT IT JUST MAKES THE CLICK SOUND BUT NO MOVEMENT. I CAN'T EVEN GET IT TO DRAIN IT WILL NOT AGITATE ON ANY CYCLE. I PUSDHED THE SPIN ONLY BUTTON AND IT MAKES A LOUD SOUND LIKE ITS ABOUT TO GO BUT NOTHING ELSE HAPPENS. SO EVERYTHING IS WORKING EXCEPT NO MOVEMENT. ALSO THE LID DOES MAKE THE CLICK SOUND WHEN BEING CLOSED, SO I DON'T THINK IT IS THE LID SWITCH, BUT I COULD BE WRONG. PLEASE HELP I HAVE A WASHER FULL OF WATER AND CLOTHES.
    How do I jump the lid switch?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The click sound comes from a bad lid switch and/or the Timer that has gone bad & needs to be replaced. Try to jump the lid switch if it works then it is the switch that has gone bad and if it wont then it is the Timer that needs to be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    Please make sure that the washer is unplugged
    completely and then remove the two wires from the switch. Once it's done twist
    them together and use a nut when you do this & wrap that in electrical
    tape. Also check this video and this is the repair/service manual for your Whirlpool Top load which will help you for repair. Please accept the solution if
    Thanks
    Rylee
    Please make sure that the washer is unplugged completely and then remove the two wires from the switch. Once it's done twist them together and use a nut when you do this & wrap that in electrical tape. Also check this video and this is the repair/service manual for your Whirlpool Top load which will help you for repair. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Thanks
    Rylee
    Thanks
    Rylee
  • Whirlpool Master
  • 3,051 Answers
Hello there:
The first thing you will need to check is the lid switch if you have the lid open take a screwdriver and press it in the slo tthat the lid closed on and see if there is a click when the machine is on if not this needs to be replaced but ifit does click
check these solutions i have provided below
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these: Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly. Clutch assembly Many washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician. Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on Oct 07, 2010
  • Michael Thomas
    Michael Thomas Oct 08, 2010
    Hello there
    yes i would have to say that the lid switch may be faulty this is pretty common on machine like this it really does not take much for them to go out If you feel like you can do the repair on this i would first get to the switch and try to bypass the switch wit a jumper wire and see but if it dosent than you may need to look else where and once again that is where the timer would come into play all machines wil fill even if the timer is not working but if the timer is not working and the machine is full it cant get a signal from the timer to begin agitating
    or any thing for that mater ok so those are the 2 things i would start troubleshoot first
    Please keep me informed
    Best regards Mike
  • Michael Thomas
    Michael Thomas Oct 10, 2010
    Hello there
    sorry it took so long to get backl to you
    if yo find where the lid switch is plugged in at simply unplug the wire and get a jumper wireabout 6 to 8 inches long and place each end in one of the plug in holes this will jumper the connection and allow you conduct further tests ok
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clicking Sound / Kenmore Elite Catalyst
sounds like ur coupler is bad easy fix 4 dollar part
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Ge washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Whirlpool GST9679P Top Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washer stops suddenly and water isn't drained out
Hi tieuvodanh; Sounds like the timer has gone out. If you can advance the selector dial manualy, and the machine continues to operate as it should, then this is the problem. Replacing the timer will require some advanced knowledge of washers and the ability to use a box of hand tools. A good handy man will be able to repair this for you. Best regards; HELP2DIY Please don't forget to rate my answer.
Jul 10, 2007 | Kenmore 22422 Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
