Question about Dishwashers
Dishwasher not filling with water.
My dishwasher is making noise so I know it is running...but it will not fill with water. The water has not been turned off.
I have the same problem. I am not sure if it the filter or not.
Posted on May 29, 2008
  • leonic May 29, 2008
    After doing some research, i have found it is either the water inlet valve or the float switch. my model nubmer is 587.15163401. How do we determine what is wrong from this point on, or should I just bye a new dishwasher? Trying to help you out chertech
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Kenmore dishwasher.not working
I decided to buy a new dishwasher! The motor was making a humming noise after the water filled, and there was a burning smell, so I decided to replace the dishwasher!!
Oct 24, 2009 | Kenmore Dishwashers
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher water level low and making strange noise.
Hi, This d/w is designed to run with low water level. The noise you are hearing might be the wash motor. Do you know if this has the single or dual motor setup?
The dual motor style are not the greatest. The wash motor is known to go bad. You can remove the housing below the spray arm and see if anything has lodge in the in impeller. Please let me know if I can assist you further.
Vic
Jun 12, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Open Questions:
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
