Question about Kenmore 45087 Front Load Washer
My front load kenmore washer ,is not doing anything. only said control locked. what the problem can be.
    Habit-Forming:
  • 84 Answers
Try unplugging the machine for 5 minutes,then plug back in,hopefully it will reset the computer
Posted on Oct 07, 2010
SOURCE: duet front load washer control locked--How do I undo??
Holding the end of cycle button worked for me.
Naples Florida 01/03/2008... Thanks!
Posted on Jan 03, 2008
SOURCE: control locked light on
Try holding down the end of cycle button for at least 3 seconds.
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: control panel locked
The following link explains how to correct a Control Lock problem for your washer:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
I know this link is for Kenmore Elite and Whirlpool Duet. The newer model Maytags are manufactured by Whirlpool (which also makes the Kenmore Elite) so these instructions should apply. Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Posted on Aug 14, 2009
SOURCE: front loading washer won't spin
my amana washer wont spin and does not drain
Posted on Sep 12, 2009
  • 193 Answers
SOURCE: Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Posted on Nov 04, 2009
Kenmore Elite washer - control light is on and ii cannot do anything? Please help how do i unlock this feature??
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
I have a "Control Locked" light on my panel and I can't do anything. The load in the waher is still very wet. How do I fix this?
Sep 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
Have a kenmore front load washer and shows pau 45 in the display. Whatever button i press shows err cannot do anything with the machine.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Jul 10, 2010 | Kenmore 46462 Front Load Washer
Control lock is light up on front face of washer. Not able to do anything
If it's a Whirlpool/Kenmore front load washer, press and hold the control lock button for 3 seconds. If it's another brand, specify make and model.
May 19, 2009 | Washing Machines
Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load... Problem
Have you tried pressing and holding the DRAIN/SPIN button down for three seconds? This button is used to lock and unlock the control panel. The instructions should be printed right under the button. If the problem isn't a simple fix, please let me know. I hope this helps you.
Jun 27, 2008 | Kenmore Elite 45986 Front Load Washer
Control Locked and will not let me do anything else
I held the Drain and Spin button in for about 4 to 5 seconds and it released.
Feb 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 45087 Front Load Washer Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
