Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My cabrio wtw6700tw1 does no rinse so the water not drain out of the basin
  • 176 Answers
Check the pump maybe some think in sid it
Posted on Oct 07, 2010
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
Whirlpool cabrio wtw6700tw1
You can buy a new pump from partsclinic.com The following link is for the part and a video on how to replace it
http://www.repairclinic.com/PartDetail/Drain-Pump/W10217134/1472275?modelNumber=WTW6700TW1
Oct 13, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not clear soap from machine, have to rinse multiple times
are you using regular dish-washing detergent....not liquid dish detergent like dawn....dawn and the like suds up tremendously....regular detergent is manufactured so it will not suds up.
does it drain completely? sometimes a blocked drain will keep enough soapy water in the basin that when the rinse cycle comes on it essentially throws soapy water back on the clean dishes.
hope this helps
Jan 21, 2010 | Haier ESD210 / ESD211 Built-in Dishwasher
Whirlpool Cabrio WTW6700TW1 that is making a banging noise
The Cabrio unfortunately has many problems. Your problem however is the four suspension rods. If you know someone who is handy it's not that bad to do yourself. Just need a little patience. There are two clips just between the top panel and the front panel. Use a screw driver and a flashlight to see the clips. Then using the screw driver, push in on the clips to lift the entire top panel. This can be difficult. Once open you should be able to see the four rods that support the tub. That's what you need. Hope this helps...
Jan 17, 2010 | Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't rinse, fabric softner still in basin and won't drain. clicking noises when chaning cycles to rinse and drain
Sounds as if the pump may be clogged or going out. You'll have to scoop the water out of the tub and tip the washer on it's face to inspect the pump. I persoanlly have had a sock be sucked into it and cause the same problem. I wish you luck, if you need more assistance, please feel free to ask me.
Mar 16, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
482 people viewed this question
Dan Webster
Dan Webster
Sal De
