Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
My lawn mower keeps stalling out but does not fully stall, and wont get up to full mowing power.
  • Yard Machines Master
  • 7,482 Answers
Check your fuel filter if you have one.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
M48a wont rev
Check cable that is not loose when you adjust power or check that there's nothing rapped around the blades could decrease the power it's supposed to give when blade is spinning
Jan 03, 2014 | Garden
Motion belt was recently replaced and the mower seemed to be operating as intended; mowed the lawn with no problem. The next time I tried to use it I discovered that, as soon as the mower deck is engaged,...
This could well be a miro switch issue, start with the seat switch make sure the connector is fully pushed onto the micro switch, if no better make sure you are fully sat in the seat to activate the switch, if still no better replace the switch.
Jul 31, 2013 | Garden
The motor sputters and almost stalls have to use choke to keep it running.
sounds like the flowt is sticking in the carb and it need a carb rebuild kit
Jul 18, 2013 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Cannot have blades engauged when in reverse mower stalls
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
Dec 11, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Mower is stalling out loosing power when i mow changed spark plug put a new air filter on and still wont run also changed gas out but wont run dies out when i mow
check main valve in carberator for dirt adjust main feed needle close and open to 2 full turns and adjust from their for max power
Aug 19, 2010 | Toro Lawn Mower With Toro Power Tools
Troy built lawn tractor keeps stalling out while mowing lawn. It starts up again, but mowes for a couple of minutes then stalls out.
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Jul 04, 2009 | Garden
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
512 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
