Good day.
Ink cartridges are very sensitive, especially as with the golden contact points. Some cartridges have small chips in it that counts the nozzle output. When the counter reached its maximum figure, the cartridge cannot be used again. You may try to remove the cartridge again and clean the contact points using a cotton buds soaked with a household alcohol. You may also clean the contact points in the cartridge bays (where you insert the cartridge). Have it dried up, install the cartridges then try again. If you receive the same error then you need to buy another cartridges.
Good luck
Tedmac
Hello, i am sorry to say that you may need to buy new inks for your machine, it seems that these new hp ink cartridges, seem to be able to take only one good refill.
These types of severe
cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem", "cartridge in wrong slot", etc.) typically indicate the internal micro-electronics
of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at
rear and lower side of the ink cartridge, are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on most models which use HP 74/75 cartridges. Refer to
Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL
Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart
C4200-C4500 and C5200-C5500a Printers -
Diagnostic Tap 41 Test: (verifies
electrical health of ink cartridges):
http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP
74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet
J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling &
Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
