Question about Sony PCV-RS420 (027242635845) PC Desktop
Power tower wont turn on. when you press the power button the blue light flashes quickly then nothing after that.
    President:
  • 2,653 Answers
First thing I would check is the power supply, easiest way to test it is to just swap the power supply with a working one.
That's easier said than done if you're just an average user so unless you've got an extra power supply handy then I would suggest finding a local computer repair shop that provides FREE DIAGNOSTICS, most do these days. Have them check out the system. It's either the power supply or motherboard. HOPEFULLY it's just the power supply though ;)
If the repair shop says it is the power supply I'd sincerely thank them for their time (5 minutes) and then I'd buy a replacement power supply and install myself ($15-25)
Hope this info helps!
Posted on Oct 07, 2010
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
I have a Phillips dcm5090/10 sound tower when I switch the power on at the plug the unit wont switch on. I know power is getting to the unit because the blue light above the cd unit flashes. I have missed...
I have exactly the same problem. One morning a couple of days ago the DCM5090 simply wasn't possible to turn on. The blue lamp at the from shines - indicating that there is nothing wrong with the power supply - but pressing the ON-button has no effect. The display is unlit. Also the charging of an iPad I usually have connected on top no longer works.
Any thoughts? Broken fuse?
Sep 16, 2013 | Televison & Video
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Can not connect
Power up headset. Press and hold the + and - Volume buttons until the red and blue lights flash . Your phone should now pair with the headset. For passcode I used 1234 and this worked.
Regards
Moss
Feb 17, 2008 | Radio Communications
Sony PCV-RS420 (027242635845) PC Desktop Logo
53 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
