Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
The refidarator freezez everything especially on the bottom. and the water dispenser does not work because the line is frozen. it started when i changed the motor fan because the the refigeratater and the freezer was not working. i even changed the control thermastat.
    President:
  • 1,891 Answers
It is prob a main pc board . it gets it info from the sensors and then control the compressor run time and the defrost cycle .. the fan when it failed may have caused over run times . . did you use the correct speed fan for replacemant . and are the coils clean. board may be good but sensor bad . .. i can hepl more with complete model # .. but try cking thes first .. mm
Posted on Oct 07, 2010
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
Water dispenser not working
It may be the paddle actuator if you have one. the water valve could be the problem. It is common especially in GE refrigerators for the water tube to freeze in the door. this will require thawing out the door for a few hours. To check there is a disconnect behind the bottom grill where you can disconnect the water line to the door. If water comes out there when the water dispenser is activated then the water line is frozen in the door.
Mar 14, 2015 | Refrigerators
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
Electrolux 23 cu ft refrigerator (EW23CS65GS1) Water dispenser problem. The water dispenser on the freezer door does not dispense water but the ice dispenser is working fine. I turned off my refrigerator...
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Oct 17, 2011 | KitchenAid 20.3 cu.ft. Counter-Depth...
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Oct 05, 2009 | GE Refrigerators
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Water despenser does not work
OK EVERYONE...
HERE IS YOUR SOLUTION FOR WATER AND ICE DISPENSERS ON GE UNITS NOT WORKING BECAUSE OF FROZEN LINES.
GET A HAIR DRYER...
USE THE HAIRDRYER TO WARM UP THE LINE THAT STARTS AT THE BOTTOM LEFT HAND SIDE OF THE FREEZER DOOR.
WARM UP EVERYTHING ALL THE WAY UP THE SIDE UP TO THE WATER DISPENSER.
WARM UP THE TUBE WHERE THE WATER COMES OUT.
(BE CAREFUL NOT TO PUSH THE WATER DISPENSER SWITCH...COMMON SENSE)
KEEP WARMING UP THE DOOR AND TESTING THE SWITCH UNTIL YOU GET WATER...
IT TOOK ME ABOUT 20 MINUTES...IT MAY TAKE LONGER DEPENDING ON HOW BAD THE LINE IS FROZEN.
I HOPE THIS HELPS...
Jul 04, 2008 | GE Refrigerators
Our ice maker will dispense water,but the ice maker does not function.i did not see a filter in the top right of the refrigerator compartment.also i tried everything in the troubleshooting guide in the...
THATS WHERE YOU START .WITH A BLOW DRYER UN FREEZE THE TUBE THATS FROZEN .NOW CHECK YOUR DOOR GASKET AND IF IT HAS ANY WAY OF LETTING AIR INTO THE FREEZER ........FIX OR REPLACE IT.I'M ASSUMING WARM AIR IS BEING DRAWN INTO FREEZER THROUGH THIS GASKET.IF DOOR GASKET IS GOOD ....REPLACE THE WATER VALVE...
PLEASE RATE THIS .THANK YOU!
Jun 06, 2008 | GE Refrigerators
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven't got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren't any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
85 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
