Question about Canon CanoScan 4200F Flatbed Scanner
I need driver for Canoscan 4200f for Vista 32 Bit OS
  • Canon Master
  • 32,281 Answers
You can download the Canon drivers from their support WEB site. Please click on this link and select your model scanner to download :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Oct 07, 2010
3 Suggested Answers
SOURCE: Canoscan 4200f Problem with Vista 32 bit
http://www.usa.canon.com/consumer/controller?act=OSCompatibilityArchiveAct&fcategoryid=2122&keycode=vistadr
Posted on Jun 16, 2008
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Posted on Jun 24, 2008
My Canoscan 4200F has no OCR software. How do I get it?
OCR software is usually a third-party program. Sometimes it is available on the original driver CD but it isn't included in the downloaded driver software. In the case of the CanoScan 4200F, the CD included the OmniPage SE OCR program. The SE indicates a Special Edition only bundled with the scanner and was only available for the OS versions that had been released when the scanner was first available. If you have the original CD (for Win98-XP), try to install the program using the Custom install option. (Check your current OS version. A 32-bit OS is more likely to support the OmniPage SE. With Windows Vista and 7, click Start > Control Panel > System and Security > System to determine the version. x64 indicates a 64-bit OS. ) If your current computer doesn't have an optical drive, use an external optical drive to install the program.
If you do not have the CD or your OS is incompatible with the Omnipage version on the CD, you will need to either purchase OmnuPage ($99 with a rebate from many vendors), AbbySoft's OCR program or one of the other OCR programs. SimpleOCR is free for personal use, http://www.simpleocr.com/Info.asp . The biggest problem with the free OCR programs is that they do not handle documents with columns properly.
I wish that I had better news for you.
May 31, 2012 | Canon CanoScan 4200F Flatbed Scanner
I cant get my Canoscan 4200 F flatbed scanner to work with Windows 7 Home version. Any solution?
You should try downloading the Windows 7 version of the software and drivers for you scanner from the Canon support web site: (click here)
From the "Select OS" drop-down, select either the standard (32bit) or 64 bit version of Windows 7 depending on what you have installed on your system.
From there, download the 4200F Scanner Driver and the CanoScan Toolbox software and select "Open" after download.
Good Luck!
May 03, 2011 | Canon CanoScan 4200F Flatbed Scanner
I need to get 64 bit driver for canoscan 4200F the file is no longer on the canon usa site and on the canon uk site it fails to download at the "accept licence" page. I also need the 64 bit canoscan...
Are you looking for the Window XP 64bit drivers? As those are not listed on Canon's support site but the Vista and Windows 7 64 bit drivers can be downloaded from the support site link below. The ScanGear software is also available on the USA site.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=10445
Robert from Blitware
Jun 16, 2010 | Canon CanoScan 4200F Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Canoscan Toolbox returns a TWAIN error with
maybe the software that you download is a 32 bit O.S only that's way it cos you and error. because your O.S
is not compatible to the software that you use. download a 64 bit driver twain
Mar 05, 2010 | Canon CanoScan 4200F Flatbed Scanner
I have an HP laptop OS Vista i tried to
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Sep 03, 2009 | Canon CanoScan 5000F Flatbed Scanner
Canon 5200F won't work under vista 32 Bit
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=10445#DownloadDetailAct
Click the Drivers and Downloads tab, Vista.
Pick the CanoScan toolbox and the driver.
Jan 06, 2009 | Canon CanoScan 4200F Flatbed Scanner
Apr 19, 2008 | Office Equipment & Supplies
Dec 31, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
115 people viewed this question
old marine
old marine
