Question about Biostar TA785G3HD AM3 AMD 785G HDMI Micro ATX AMD Motherboard
Onboard lan not working even after update of driver gives windows error
  • 386 Answers
Hi Good day!! What message of windows error? Check your network adapter in the device manager, if it is install if not pls try the following.
1. On the desktop right click "My computer and then properties"
2. go to Hardware tab and then click device manager check the network adapter.
3. Disable it and then re enable it. hope your on board lan will work now if still not re-install your lan driver through your motherboard cd..
pls reply o assist you more..
REGARDS:
JR
Posted on Oct 07, 2010
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
Hi my laptop is LG my internet explorer is not open. i'm using window XP I did not configure the LAN ethernet. could you please send me the LAN driver software of LG S1 PRO express dual
HI
FIRST DOWNLOAD THE DRIVER from the below link then after downloading unzip the LAN.ZIP.THEN go to device manager select & click on network adapters then rigt click and select update driver and given the unzipped path.
http://www.notebook-driver.com/lg/lg-notebook-p1-pro-express-dual-driver-for-windows/
OR
http://www.notebook-driver.com/lg/lg-notebook-w1-pro-express-dual-driver-for-windows/
[LAN] OnBoard Agere Systems LAN Driver_XNOTE Win2000
WinXP LAN.zip 2,459K
[Wireless LAN] Intel Pro/Wireless ABG Driver_XNOTE(P1) Win2000
WinXP INTEL_wireless.zip 3,941K
May 20, 2011 | Computers & Internet
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek...
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Mar 19, 2011 | Intel Motherboard
MY LAN CARD IS NOT WORKING.ONCE I GO TO DEVICE MANAGER IT SHOWS AN ERROR MARK IN THE ADAPTER PLACE LOGO.BUT THE HARDWARE IS CONNECTED.WHEN I GO TO INSTALL THE DRIVER ,IT DOESNT GET INSTALLED TOTALLY AND...
If it is not onboard LAN card reinsert it after cleaning it's concact point with pencile eraser. And user proper driver for it. I think you don't have proper driver for your LAN card.
Oct 29, 2010 | Computers & Internet
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
I Have ASUS P5RD1-VM series motherboard of which the LAN driver is being missing all the time. Pls. anybody help me. Regards Sachin
Open Advanced while in the bios. Than open Southbridge configuration.
Please check bios for Onboard LAN Page 2-24 in you're manual. Set this to [Enabled]
If you do not have this enabled the LAN controller will not function.
Once enabled in bios save and exit the bios menu.
Open windows update when you're system reloads.
Click the custom button when windows update open’s.
Windows update service will scan you're system and will see you're LAN is enabled.
Windows will list drivers for you're on-board built-in LAN controller.
Or you can use the Asus CD to install the LAN controller software.
If you're LAN controller does not function you may need to add a PCI eithernet card.
Mike
Apr 12, 2010 | ASUS P5RD1-VM LGA775 Motherboard - ATI...
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Dont have motherboard cd,m not able to find LAN Drivers on net
You have 2 choices. 1. Call Intel tech support & see if they can find a solution for you or 2. Install a standalone ethernet/wireless card, depending on your setup and disable onboard LAN. I had to go the 2nd route as my onboard LAN wass not compatible with Windows Vista. Hope this helps.
Dec 24, 2008 | Intel D845GLLY Motherboard
Cannot get the onboard gigabit lan to work?
You need the chipset drivers for the motherboard, to get the onboard ethernet adapter to work. Try this link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
If the link doesn't work, go to ASUS address, select the download option, then in the pull down menus, select:
> Motherboards
> AM/AM+
> M2NBP-VM CSM
You'll be prompted for your OS, so pick the correct one, then you'll be at the download page for all your drivers - Chipset, sound, graphics, etc.
Cheers
Nov 13, 2008 | ASUS M2NBP-VM CSM Motherboard
ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Aug 11, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Biostar TA785G3HD AM3 AMD 785G HDMI Micro ATX AMD Motherboard Logo
137 people viewed this question
Top Biostar Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
