Question about Maytag 24 in. MDB3700 Built-in Dishwasher
It appears that my dishwasher isnt working as well as it should. i think it needs cleaned. what do i used?
Washing isnt coming out as clean as it used to... often appearing stained in areas. Filter is always empty of lint. Is there a way i can clean the actual machine???
If you have hard water,,, that is a big if ,,,,, Make sure your softener has pleanty of brine salt and that the softener is working properly. Soft water = bright clean clothes.
Jan 11, 2014 | LG Dishwashers
My dishwasher isnt using the soap I put in the main wash compartment. Ive ran it 5 times using different kinds of soap and it isnt doing anything. The compartment that holds the soap isnt popping open...
Hi, The soap dispenser may not be the problem. It could be that it's not getting enough water. Is the pump running and water cleaning the dishes. Then there is no problem.
Jun 27, 2011 | Dishwashers
Recently my dishes have a film on them so I decided to use a liquid dishwasher detergent, thinking that the dishwasher detergent was the problem. The liquid did not get used up at all , it just melted to...
This sounds like a water flow issue, suspect is IN and OUT. In has screen that is located in inlet valve, it needs cleaning, the exiting water is more difficult to clean, as most everything has to come apart. BUT, if you have enough water getting IN, you would likely dissolve the detergent, so I suspect supply problem.
Jun 25, 2011 | Whirlpool Dishwashers
It says CL washing and obviously isnt working
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | Frigidaire 24 in. PLD3465REC Stainless...
It appears that water is not running through the dishwasher or that the sprayers are not working correctly. There doesn't appear to be a clog. However, I did find a round rubber "washer" (I think that is...
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Aug 27, 2010 | Hotpoint Dishwashers
Dishwasher not working
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 13, 2010 | Whirlpool 24 in. ADP5740 Free-standing...
Motor not working
Your motor is attached to the pump,your pump seal is locked up needs replacing or purchase a new pump.Because it is a job replacing seal,if your a first timer.
Apr 10, 2009 | Kenmore Elite 20972
Dishwaser working,but not cleaning dishes properly
unfortunately, there is no way to run it and see what it is doing. the only way to check if the spray arms are working properly is to put your ear up to the dishwasher while it is running. you should hear the water spraying along the door panel on both the top and bottom ( Note: some dishwashers run the spray arms simultaneously and sometimes they run at seperate times ).
another thing to check is your water temperature. the water must be 120 degrees in the dishwasher in order to clean the dishes properly. also, if your kitchen sink takes a while to get hot water, you will need to run the sink first prior to starting the dishwasher. I have to apply this method at my house because it takes a while for the water to get hot at my sink. if I run it without starting the sink, the water in the dishwasher is 80 degrees or so and will not clean properly. Joe
Nov 18, 2008 | Dishwashers
Neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Kitchen Aid Superba Dishwasher filter replacement problem
I dont think that it is made for you 2 move it.
If it isnt dirty then there isnt really no use. But if it is dirty write back and ill try to help you :)
Sep 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
