Question about Kirby G5 Bagged Upright Vacuum
My belt fell off and i need to know how that and the brush part goes back on
  • 171 Answers
You need to refer to the video to help you if you haved it other wise it can be done by turning thr plastic nob which is almost flat on the fro\nt of the head. turn it all the way to the left and thyen push the haed against theunit and turn the knob all the way the other way if this doesnt work repeatit butg start with the nob turned akll the way to the rtight first.
Posted on Oct 07, 2010
The brush part doesn't spin anymore. I checked it and a little blk rubber piece fell out
For the brush to stop spinning, this suggests the belt has snapped or come off the motor. The little black rubber piece which fell out may be the remains of a chewed up belt. I suggest checking the belt is where it should be, may be hidden under a removable cover, and that it is stretched round the motor spindle.
Oct 17, 2014 | Vacuums
Dyson DC14 Bar brush and belt replacement.
Try the op manual http://www.dyson.com/customercare/manuals/us/dc14_opmanual_usa.pdf
Aug 30, 2007 | Dyson DC14i Bagless Upright Cyclonic...
Bissell carpet cleaner belt fell off, how do I replace it
Which belt? There are 2 on a Pro Heat. The pump belt which is pretty straight forward to put on. If it's the brush belt you will probably have to take the brush off. Re-rail the belt and then put the brush back in the holder arms while keeping the belt in the groves. BUT if the belt came off in the first place it's probably shot. Before you go to the trouble, get a new belt.
Sep 25, 2014 | Bissell 1699 ProHeat Clear View Upright...
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
The brushes will not turn
Check to see that there is a belt around one end of the brush -- belt may be broken. If the belt is intact, let me know and we'll go to the next step.
Charlie
Feb 01, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
May 08, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
My front wheels fell off how do I fix it. there is a slender long spring and I don't know where it goes
That spring connects to a slot beside the height adjuster knob and a hole in the base to the wheels that fell off.The problem is you can't get the wheels to go back in flush so the height adjustment works.The vacuum will not be close enough to the floor to get any type up suction or brush contact.To change that spring as well as the belt,remove the cover by taking out two screws,one on each side.Force the rller out by prying the right end out of the slot.
Feb 23, 2010 | Eureka 2997AZ Bagless Upright Vacuum
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Dyson
Hi.
If the brush turns freely then you will need A new clutch unit fitted to your machine.
There are loads of them on Ebay very reasonabley priced only buy new not second hand.
Manuals are available to show you how to strip down the machine from here http://dysonmanuals.llc.nu/
Jun 28, 2008 | Dyson DC07 All Floors Bagless Upright...
Hi....Need Help please....
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
63 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
