Question about Onkyo TX-SR605 Receiver
Can hear volume on tv but cannot see picture...tv flickers like it wants to come on but it does not....screen is dark and continually shows hdmi like it wants to come on. the tv before would turn on after about 15 minutes of letting it warm up
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
Many people who use A/V receivers use them to switch only the audio. ie, hook up all your video sources to the TV, and switch between these sources using the TV remote. Just connect the audio cables from your video gear to the Onkyo. The reason is that video signals are more susceptible to problems in A/V receivers than audio signals. better to connect the video sources directly to the TV.
You may want to ask for more clarification about this.
Posted on Oct 07, 2010
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Sony bravia sound stuck
For a little more you can get a new better set with warranty. A no brainer.
Mar 21, 2017 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Picture tube for 60 in' mitsubishi it shows only a black screen but you can still hear it
ts will go into shutdown when a vertical issue is present but the audio will still continue to operate normally.
Apr 02, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Vizio 48 flat screen has sound, picture will not come on right away
What cable is being used? Often times there is a few things that could effect the picture and causing flicker. If you are using an HDMI cable, or the hdmi plug on the box or tv, you could have that problem. Because the picture is digital, you don't get the snow and lines we were used to. Because the cables are so stuff, often over time they can stress and pull on the plug and cable. Try a new cable, if that does not work, try another hdmi input on the tv. If that fails then try a new cable, like a component cable or RCA. If none of these work and you still have this issue with the box then most likely it is the tv or the box. Swap out a new source, and start this process all over again. If you get the same result then it is the tv. If it works with the same cables, then it is your box. Att will send you a new box if that is the case. If it is the tv, call Vizio. Warranty or not call them. If you are sure you are out of warranty, play dumb, be vague but nice. Often you can get someone out there still at no cost.
Oct 18, 2012 | Televison & Video
TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Aug 12, 2009 | Yamaha RX-V663 Receiver
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
When The HDMI cables are connected, I use Directv, I have just recently started to have the picture come on and then start flickering and various color bars pop up on screen, then the screen will go black...
It is possible that the HDMI cable is defective. Did you try another cable?
It is also possible that the HDMI port on the TV is failing.
This can be determined by the process of elimination.
Jerry G.
Jun 06, 2008 | JVC Televison & Video
Onkyo TX-SR605 Receiver Logo
102 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
