Question about MSI Computers & Internet
Motherboard manual needed
On/off switch connector came disconnected from motherboard, I dont know where to reconnect. Also pc wouldnt power up. I replaced power supply to no avail.
  • 5 more comments
  • gube May 29, 2008
    either K8NGM2 H or MS7207
    everything is all connected properly, but the pc wont turn on. brand new power supply in place but when I push the power button, the fans kick for a brief moment and thats it.
  • gube May 29, 2008
    no beeps. I wasnt able to turn the pc on for about a week, until last night after I took it apart and blew all the dust out. I plugged it back in and it fired right up. when I went to turn it on again this morning, the problem was back. Hence the new power supply.
  • gube May 29, 2008
    AMD
  • gube May 29, 2008
    Well I finally figured out what was going on. My nvidia
    e-GeForce 6600 256 MB video card was the culprit. I removed the card and my pc fired right up. Now I have to figure out how to flash the BIOS so it will read the onboard video card instead of the above mentioned card. Any suggestions out there? Thanks
  • gube May 29, 2008
    My problem now though is there is no video output to the monitor. I am going to have to reset the BIOS another way, hopefully so it will revert back to the original on board video card.
  • Chris Hall May 11, 2010
    are you getting any beeps?
    whats the model number of the MSI motherboard?
  • 43 Answers
Amd or Pentium?
Posted on May 29, 2008
  • 1 more comment
  • Chris Hall May 29, 2008
    hmmm seems like something is happening before the motherboard can post. Kinda like something isn't plugged in right or there is a short somewhere.
    It always helps to take it apart again and put it back together.
    good to hear youve figured it out. On the bios problem you gonna be looking for something to do with video and it has a setting thats gonna ask where you want the computer to look for video first and you just set it to onboard.
    the setting is usually under advanced settings
    it should auot default back to onboard for the bios screen
Reconnecting the pwr switch and HDD Led wires,etc
Hello here are the manual in pdf:
http://pclap.hu/driver_files/nf7_series.pdf
You will need adobe reader, to read content.
The front panel connector, look likes this:
Here are the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Good luck
Sep 24, 2012 | Abit nForce2 NF7-S2 Motherboard
I have an acer e500 tower wont boot a cable from what looks like the front panel near on switch is disconnected from motherboard and i dont know where it fits
Should be an input that says pwr or pwr sw on the motherboard. Really the power switch input is usually 2 pin and the only one on the mobo.
Sep 20, 2012 | Acer Aspire E500 PC Desktop
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
Cpu fan stop few second after starting pc
Hello,have you installed new motherboard or CPU?
Follow these steps again
1) Disconnect the power cord from the back of the computer & open up the case.
2) Wear an anti-static glove or at very least discharge your static by touching a metal surface or power supply
3) Disconnect the main 20pin ATX power connector from the motherboard & the square 4pin ATX2 power connector
4) Remove any PCI cards you have & disconnect ALL drive cabling from the MOTHERBOARD. Also disconnect any internal USB fly leads from the motherboard.
5) You should now have ONLY the cpu+heatsink/fan, memory & video card installed. Locate the round silver battery in the bottom right corner of the board. Just below it, you'll see a plastic jumper cap. This cap should be covering 2 pins (pins 1 + 2) with pin 3 bare. It will be marked JP1. Move the jumper to cover pins 2-3 instead. Leave in this position for about 30 seconds, then return the jumper to its original position (pins 1-2).
6) Reconnect the square 4pin ATX2 power connector & the main 20 pin ATX power connector. Make sure that the case speaker or buzzer is connected also.
7) Make sure the only external devices connected are the keyboard/mouse & monitor. Reconnect the power lead & power on the system
Let me know what happens
Feb 06, 2010 | ASUS M2N68-AM SE2 Motherboard
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
Mb have power but not start...
Hi, good day sir, there are several things you should do first.
1. Disconnect all connections to the motherboard.
2. make sure that your Power Supply 4pin 12volt molex and 24 pin molex connectors are tightly plug.
3. Clean the memory port from any dust, plug the RAM module, make sure also the module connector is clean.
4. Plug in the speaker and power switch.
5. Connect a VGA monitor.
6. Reset bios/cmos or simply operate the pc without the battery.
7. Plug the Power Supply to AC mains.
8. test the PC.
9. do this several times if you cant start the PC.
10. if every thing is OK, reconnect your PC and peripherals one at a time.
Hope this helps.keep me inform about your progress. thanks
Jul 30, 2009 | Intel D945GTP Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Ok my dell that i have is a intel celeron d dimension 1100 with windows xp home on this is the prob with it i pluged it in with tha power supply and tha green light comes on but whe n u hit the power...
The power switch/button may have a polarity issue. Remove the power cable from the back of the PC, then swap the power switch connector on the motherboard 180 degrees (put the connector with the two different color wires back in the opposite way it was on).
Dec 02, 2008 | Dell (8N816) Motherboard
How reconnect my Gigabyte GA-8IDX3, please Help me....
if you download this manual, the instructions are on page 23 labeled G:F_panel http://europe.giga-byte.com/FileList/Manual/motherboard_manual_8idx_e_1006.pdf
Apr 28, 2007 | Gigabyte GA-8IDX3 Motherboard
Computers & Internet Logo
91 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
