Question about Garden
What year was the poulan micro xxv deluxe 25d-33ccm made?
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: I have a poulan micro s25d 33ccm super xxv deluxe
As to the proper amount of slack in the chain, new or otherwise, is you should only be able to left the chain from the center of the top bar, so that you can only see the drive tooth of one (1) of the links.
Now with a new chain, the trick is to check the slack after the first tank of gas has been consumed, as new chains tend to "relax/stretch" after being put into service.
But with that being said, I always check the chain at each fueling and filling of the bar lube tank too. Better to be safe and get the maximum performance from your chainsaw, and there is no better way than to keep everything in proper working order.
A good rule of thumb is to:
  1. check and readjust/tighten the bar/chain after the fuel tank runs out of gas/oil mix. (wait for the chain/bar to cool before grabbing it with your bare hands!)
  2. Refill the bar/chain oil
  3. Refuel the chainsaw with the proper gas/oil mix, (typically 40:1)
  4. I always add fuel stabilizer to my fuel tank after I'm done using it for the day (who knows when you'll use it again!)
  5. Take a hand file and give the cutting chain a quick "touch up" sharpening before putting it away.
If you follow these steps, you'll always have a working chainsaw, ready and sharp enough to cut when you need it, without any surprizes, etc.
I hope you find this Very Helpful and best regards!
Posted on Oct 21, 2009
Testimonial: "Thankyou very much. This is very helpful!!"
Trying to find a service manual for this. can you assist? thanks
Hi Linda:
Here's a link that will get a lot of sites where you may be able to get the manual. Just click on it.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Poulan+Micro+Xxv+Vintage+Chainsaw+service+manual
Hope this helps.
Keep those old machines running!
Cheers
Apr 02, 2016 | Poulan Micro Xxv Vintage Chainsaw Coil...
How does the oiler work on a poulan micro xxv
The oiler operates off the crankshaft under a cover behind the sprocket. Find the oil port near the back end of the guide bar where the oil pump injects the oil onto the chain. That port could be plugged. Your little Micro probably does not have an adjustable oiler but just in case invert the saw body and see if there is a + and - in the casting just under the sprocket. If so, moving the slotted adjustment towards the + increases oil flow.
Sometimes sawdust enters the tank when being filled and plugs up the inlet to the oil pump. Keep an old 1" paintbrush with your oil can so you can brush away the debris before opening the oil tank to fill while in the woods.
Sep 23, 2014 | Poulan Micro Xxv Vintage Chainsaw Coil...
We need a manual to help replace the fuel line on a Poulan Deluxe Super 25
You do not need a manual; exactly like the video that follows:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
No primer or second carburetor connection. Be kind to the oil pump; they are no longer available.
All fuel components are on the "Ignition, Electrical & Flywheel" print here (filter and hose are available):
http://www.ordertree.com/modelinfo/PWE/MICRO-XXV-Gas-Saw/75.MICRO-XXV-Gas-Saw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Micro Super XXV Deluxe S250?
Just like the video:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 26, 2010 | Garden
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Looking for a workshop manual for a poulan micro xxv deluxe Thank you
This is Poulan.com "POULAN-WEED-EATER" and your model number"Micro xxv"
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=MICRO XXV Gas Saw&AFID=59
HTH
Lou
Aug 04, 2009 | Garden
Poulan micro xxv wich will run for 5 mins then flood but why?
clean out the vents on your fuel cap. you may also have sawdust or dirt stuck on the diaphragm in the carburator
Feb 25, 2009 | Poulan Garden
Garden Logo
349 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
