Question about Denon Audio Players & Recorders
Headphone socket I have a Denon 1906 receiver. A headphone plug came apart inside the headphone socket, now the receiver thinks there's headphones plugged in all the time, so I can't get any sound at all. Do I need to have the whole socket replaced?
  • twelvetwelve May 29, 2008
    The headphone socket is mounted on a small PCB separate from the main PCB unit. The socket itself is completely enclosed in plastic, so I can't push the piece out from behind.
    I'm thinking the only thing that can be done is to have the socket replaced, but I don't know if it's a proprietary piece that Denon will charge loads for. Also, I heard their service takes months and I'm not prepared to wait that long.
    Will the entire smaller PCB need replacing, or is the socket a generic part that could easily be removed and replaced?
  • twelvetwelve May 30, 2008
    Hey
    1. From the bottom
    2. No, it's all black, and appears to be completely sealed
    I am in England. I'm not speaking from my own experience on this repair matter, but several people I've spoken to have said getting their equipment repaired through Denon has been a nightmare. Long delays, etc.
    Sorry about the 'Thanks for trying' rating. I had no idea it was perceived that way!
  • 1,512 Answers
Hi twelvetwelve
Are you able to get access to the rear of the socket and use a small screwdriver to push out the parts of the plug that have come adrift inside the socket? You may have to actually remove the socket from its PCB to get access. If you cannot remove the offending parts, then you may have to replace the socket. There is not alot more that you can do unfortunatly.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
  • Graeme Ross
    Graeme Ross May 29, 2008
    Hi again, The socket is supplied as a spare part without the PCB, and although quite common socket 6.5mm stereo jack, , may be difficult to source a generic part to fit the pin layout and switching options required for your unit.
    I have over the last 25 years repaired several different units with your problem, and have not had to replace a socket yet!!. There is generally a way to sort it out without replacing it. If you can bear with me, I am sure that we can come up with a solution. A couple of questions for you.
    1. Does the PCB mount from the bottom or the rear of the socket.
    2. Does the socket has a clear plastic top.
    I am downloading a service manual from here as we speak to help me to help you sort out the problem. My business Brisbane Electronics Denon authorised service agent here in Brisbane, Australia for 17 years till 2003. You would have had no problems or delays with service from my own point of veiw. Where abouts in the world are you?
    A thanks for trying rating generally is reserved for a poor response to a question raised in this forum. I am certain that I have more to offer you than a "Thanks for trying" rating accomadates. I will continue to assist and help to sort out the problem with you if you are able to upgrade the rating that you have given me. :)
I have a Denon 1513 that was working fine last night for the game. Got up today to watch redzone turn on clb/sat and no sound. Tuner works but no sound from tv. Unpluged optic wire from both. Help
Try plugging in and unplugging headphone to the headphone jack. This model has an intermittent problem with the headphone jack that makes the receiver think there are headphones plugged in even when there isn't. Inserting and removing a plug sometimes clears this.
Oct 18, 2015 | Denon Audio Players & Recorders
HOw do I reset a Denon AVR-588
Try plugging in headphones and see if it works that way. Sometimes there are contacts in the headphone jack that get shorted and make the receiver think there are headphones plugged in even when there isn't. Plugging and unplugging them will sometimes clear up the fault.
Dec 17, 2014 | Denon AVR588 Receiver
Denon avr 1700 hp/only. how do I turn headphones off only?? I reset but did no work. can I clear the memory by unplug power, fuses ect??
try plugging in headphones and unplugging them. the headphone jacks have a tendency to have a shorted contact in them that cause the unit to think there are headphone plugged in all the time. Only true fix is to replace the headphone jack, but pluggin and unplugging can temporarily clean the fault usually.
Sep 27, 2014 | Denon AVR-1706 Receiver
Same problem as below, I have the Denon AVR 790 and the sound keeps switching to headphones. Blowing into the socket did not help. Both unpluging the AV and putting the headphones in and out fix's the...
The unit thinks there are headphone plugged in even when there are not. You need to have the headphone jack replaced. This is a common problem with this model. Another way to fix it if you don't plan on using the headphone jack is to unplug the cable going to the headphone jack board. This will disable the headphone jack, and stop it from sending an erroneous signal to the micro.
Jan 31, 2014 | Denon Avr-790 - 7.1 Channel Home Theatre...
Music still comes out of my speakers when I have headphones plugged in??
Some receivers have a speakers on off button. But if the Denon doesn't and inserting a headphones used to switch the speakers off. The don't worry it's nothing serious. All that likely to have happened is that inside the headphone socket some "pins" have bent out of shape and are not contacting. Depending on the type of socket, these can be bent back into place sometimes. But even if the headphone socket needs replacing they are not expensive and if you are any good with a soldering iron you could do the job yourself.
Aug 18, 2013 | Denon AVR-1082 Receiver
I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me...
Try plugging in headphones to the headphone jack, then take the plug out. Some models of Denon receivers had faulty headphone jacks in them that caused the unit to think there were headphones plugged in even when there wasn't.
Mar 22, 2013 | Audio Players & Recorders
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
My Denon AVR 1708 display shows "h/p only", which
Hi
H/P means Headphone .. if you plugged a Headphone or if the plug switch internally switched to H/P you have to check it out .
you might have broken the plug inside or some parts are left in there.
Regards
Nov 02, 2017 | Denon AVR-1708 Receiver
H/p input on
I had a similar problem and solved it by simply blowing in the headphone jack (h/p input).
Dec 20, 2007 | Denon AVR-1907 Receiver
81 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
