Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I recently moved my Hitachi UltraVision Digital 54" HDTV from one house to another and after having it connected find that I have double/triple images, with red and green overlays. I've tried adjusting the color, sharpness, contrast, tint, and have gone through the auto focus process but the problem persists.
    President:
  • 2,777 Answers
This is indicative of internal hardware failure on the TV for sure. Did you move it yourself or have someone move it? If you had someone move it you could file a claim with that company and they will repair it. Otherwise it will need some major repairs. Have you done TV repairs before yourself? If so I can let you know the parts you will need, but chances are the will be expensive :(. What is the model number of your TV as well? It should be found on the back on a label..
Tim
Posted on Oct 07, 2010
I have i hitachi ultravision that has a green line and makes double faces
If the convergence is so far out that you cannot adjust with your customer access menu then You will probably need the convergence ICs replaced & possibly a fuse or resistor or 2. Then a complete convergence will be necessary & I HIGHLY recommend having a professional technician perform this task.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
I have a Hitachi ultravision digital Hd Tv(Model: 43UWXtenB V2A04one295) which shows double or triple color images at the same time. How can I fix this easily ? Thanks for any advices. Sound speaker is...
This tv problems u can't fix it easily,u must take the tv aparts and change an electronic board that call the T-CON board to fixed this problems.If this problems double or triple images not causes by U or an objects by outer forces hitting the LCD screen panel itself,if yes this problems causes by U or an objects by outer forces hitting LCD screen panel itself.This tv problems can't not be repair,because the LCD screen panel itself it is dead and damages leaking radiation,if got hit by an outer forces,if screen damages by outer forces,this tv only can used as salvage tv for it electronic circuit boards for other tvs for as parts only now,because if the tv require a new LCD screen panel will cost the same as a new tv.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish T-CON board for the replacement.
Jul 28, 2011 | Hitachi ULTRAVISION L42V651 42 in. LCD...
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Lamp box is open or assembled wrong on my Hitachi Ultravision DLP 2005 model
it is in the front pop the front cover off, look in the owners manual
Jun 01, 2009 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Hitachi hdtv ultravision digital projection tv. #53udx10b. Issue: Blue halo around the body of people.
my picture is distorted and showing double. The characters are orange and I can't read the menu items because they are also showing double.
Sep 21, 2008 | Televison & Video
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Problem with red on one side
all you have to get to the convergence area to adjust that quadrant thats bad
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision rolling horazontal lines
Mine has the same thing when I have a Component AV S-Video Switch (one that can have muit- rca connections along with coax TV line on it ) the component switch caused interference and caused that line
Oct 14, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
