Question about Honeywell CT500 Digital Heat / Cool Manual Thermostat Heater
I cannot set the heat temperture and time on my honeywell digital thermostat.
  • Honeywell Master
  • 43,501 Answers
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Oct 07, 2010
Honeywell thermostate will not kick off on set temperture
There's a "throttling range." The unit starts (say, in heating) one degree below setpoint and shuts off two degrees above set point.
You can change the "temp" but you can't change the throttling range.
Mar 02, 2014 | Honeywell Programmable Thermostat Heater
How to get temperature reading on thermostat after a power outage
Normally the room temperture shows in display and setting temptr blinkering while you press the setting
Dec 02, 2010 | Honeywell Electronic Programmable...
My honeywell t87n is adjusting the heat setting by
This sometimes happens over time with some digital thermostats. The easiest solution is get a toothpick and hit the reset button. From there just set it as you normally would. That should solve your problem.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Honeywell Heat/Cool Thermostat
The furnace shuts off before set temperture is reached
This could be normal. Some thermostats are designed with a heat anticipator. The anticipator takes into consideration heat that will remain within the system after the burners shut down, it anticipates the "left over" heat will be enough for the thermostat to reach it's setpoint. If it did not have this function the setpoint would be overshot.
If you are suggesting it shuts off well below the desired setpoint please clarify.
Dec 01, 2009 | Honeywell Electronic Programmable...
I set the heat on 75 on emheat. heat in home temperture keep getting higher and higher so it get to hot
On some Honeywell Tstats you have a jumper from e on the stat to w2. If it is the stat I think if you have E hooked up without going thru w2 it will stay on cont. Remove wire from e and put jumper from e tow2. Rus
Oct 17, 2009 | Honeywell Electronic Programmable...
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
966 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
