Question about Husqvarna Huskylock Computerized 936
While quilting with clear polyester thread, the upper bar keeps dropping the thread or the thread breaks. What is the secret?
  • Husqvarna Master
  • 7,365 Answers
Try these suggestions
the needle top thread tension is to tight
the needle is bent or blunt
the thread & needle are not compatable--here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
you said the upper bar keeps dropping the thread--I think you are talking about the thread take up lever-an old sewing machine service tech I knew had a sewing machine that had that problem & he took a pair of pliers & closed the gap in the thread take up lever hole & the customer never had a problem with the thread coming off the thread take up lever again.
Posted on Oct 07, 2010
CANT QUILT WITH MY JUKI TENSION PROBLEMS
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into trouble...like spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are using...like is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Basic Maintenance Tension Skipped Stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
10 reasons for skipped stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
What kind of thread do I use for the Expressive 820
You would use sewing machine thread depending on what you are sewing. If you are embroidering, you'd probably want to use embroidery thread. If you are quilting, you would probably use cotton or quilting thread. If you are sewing garments, then you will probably want to use polyester or polyester-wrapped cotton thread.
Be sure you are using the correct needle corresponding with the thread and project. (You don't have to use Schmetz needles, but this is a great guide.) Also, change the needle often to avoid sewing problems.
Schmetz Needles Needle Guide
Dec 12, 2016 | Sewing Machines
How to get the hand look quilting stitch on the Lily 540?
Hello Joyce Smith
Please refer to page 45 in the instruction manual which can be downloaded for free at this link
http://manuals.husqvarnaviking.com/
Instead of using invisible nylon, if at all possible use invisible polyester thread. It behaves better and does not break during prolonged stitching. Use a "Quilting" needle size 80/12.
Happy Sewing
Sewingirl/
Oct 19, 2015 | Husqvarna Lily 540 and 550
Hello Joyce Smith
Happy Sewing
Sewingirl/
I am quilting and the thread keeps breaking. What is the problem?
Not sure if you are piecing or trying to free motion quilt. If FMQ, try using an Embroidery needle (it has a groove in the shaft that helps protect the thread) or a Topstitch needle. Make sure the thread is not too thick for the needle's eye. Check to make sure the upper and lower tensions are not too tight. You might try changing brand/type of thread.
Here's a needle guide:
SCHMETZ Household Needle Chart
Or review suggestions for breaking thread here:
Why is my thread breaking
Hope this helps!
May 20, 2015 | Sewing Machines
Top thread keeps snapping on consew 230b
Top thread snapping. Do you have an idea of there it is breaking?
First I would check the needle throat plate and needle. If you have stab marks on your needle plate, examine it closely for a crack. (get out the magnifying glass or jewelers loop) I recently fixed a problem I had with an old singer that kept breaking the top thread by replacing the needle plate. The old needle plate was so damaged it had actually made a knife edge which consistently cut the thread right at that location.
Change your needle and make sure it is the proper size for your thread. Too narrow of an eye can shred the thread causing it to break.
Next, check anything along your threading process that could be catching or snagging the thread. A worn or chipped thread guide can be a real problem.
Also make sure your thread hasn't dropped down below your thread cones and wrapped around the thread spindle. This would cause extra tension that might not be readily apparent.
Good luck
Aug 15, 2012 | Consew Sewing Machines
Started machine quilting; first pass went just fine, rolled up quilted portion, then started machine again but the bobbin thread broke and continues to break. Took out bobbin, reset it in case, etc. N
from what you said about the bobbin thread continues to break
check for burrs in the following area--even the smallest burr can cause problems
bobbin
bobbin case
needle plate
needle could be damaged
or bad thread
Feb 10, 2012 | Juki TL-98Q
Thread breaks
If the thread is feeding from the spool without hanging up, the problem is within the threading system.
If this machine auto-threads, try to manual threading.
Call your dealer and tell them what is happening and you need their assistance. The machine may have to be serviced. Take a sample of the problem with you.
Too many bells and whistles can sometimes be, too many bells and whistles!
Mar 14, 2010 | PfaFF Sewing Machines
Thread keeps breaking
Check first that you are using premium thread (not the cheaper type that you'd use in an overlocker/serger). Breaking thread could be because of one of the following reasons -
the upper tension is too tight, the machine isn't threaded correctly, the thread doesn't suit the fabric (I had the problem when sewing an item the other day and changed from cotton thread to polyester and it stopped breaking). In your instruction manual check at the back for a troubleshooting section where it should be listed with some solutions.
Jul 08, 2009 | Husqvarna Husky 165
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
71 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
