Question about Olympus FL-36 TTL Flash
Olympus FL36 flash unit
Hello, i have an olympus e510 and have bought a compatible flash - olympus FL36. I would like to know why the control panel does not light up when the camera is on, as the E510 has communication capabilities to enable this function, as described in the instruction manual of the flash unit, page 11. This is not happening and I have to do this manually everytime I want to look at the settings, at night. Can you please clarify whether it does, or does not have this function.
Also, have any other owners of the E510 had problems with the print on the body and buttons wearing off. This happened to me within the first 5 months when I noticed this occurring.
Also, the front rubber grip on the right side of the camera has fallen off as well, and I am very particular on the care and how I look after my camera.
I was told that sweaty fingers or the constant removal of the camera from its carry bag was the problem. I use my computer every day for many hours, and the print has not faded off that. It is being repaired under warranty by a very good repairer.
Thanking you
Angela
  • 3 Answers
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see. The flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu, Get hold of your manual or download one My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
Posted on May 11, 2009
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
I have an olympus e510.when i take pics inside or in darker areas the flash goes off alot.how can i fix this
That's because you are using auto focus. That system needs light to actually focus. When it's lacking enough light it uses the build in flash to create enough contrast to focus the objective.
Solutions :
- change to manual focus (mf)
- mount a external flash: then a different method to focus is used
- use a small pocket lamp (the light it produces fades away in the flash)
Sep 16, 2011 | Olympus Evolt E510 Digital Camera
Is the olympus mju 300 digital camera compatible with windows 7
Hello
Yes, this camera is compatible with windows 7.
Let me know if you need any further assistance.
Kind regards
Andrea
Sep 12, 2010 | Olympus MJU 300 Digital Camera
How to use olympus e520 in less light
The first answer is from some one who obviously is not familiar with Olympus (and many other brands of DSLRs) or he would know that many lenses do not have manual focus scales to use. Olympus Standard Grade lenses do not include a focusing distance scale.
The more important issues for you are determining -
1) Are you trying to use "Live View" to focus?
If so you are using a less sensitive auto focus mode. One of the benefits of using a DSLR is that it can use more sensitive auto-focus systems than Point
Sep 05, 2010 | Olympus Evolt E510 Digital Camera
Why does my olympus FE-270 digital camera drain battery really fast. i have used all types of batteries, but to no use
Link
Your camera might need a battery replacement. Make sure that the battery your going to buy is compatible to your unit. Kindly refer to above link for accessories, compatible to your camera.
God Bless.
Jul 30, 2010 | Olympus FE-270 Digital Camera
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Rm-1 Olympus remote. I have 2 of them and can not get them to work with my Olympus E510. New Batteries, tried to set frequency. No luck. Any advise?
Starting on page 45 of the user manual explains how to use your RM-1 remote control. You have to set up the camera in remote control mode in order to fire the RM-1.
May 10, 2009 | Olympus RM-1 Remote Control
Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Mar 11, 2009 | Olympus Safe Hot Shoe to PC Sync Flash...
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
Open Questions:
Olympus FL-36 TTL Flash Logo
661 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
