What's wrong with my acer 4741? the sound is very low. I have adjust the sound level to the highest level. but it still doesn't work. please give me the suggestion
    Guru:
  • 166 Answers
INSTRUCTIONAL STEPS
  • Click the "Start" button on your screen, then click on the "Control Panel." Double click on the "Sound and Audio" icon.
  • Click the "Place Volume Icon in the Taskbar" option to have it in the lower right corner. Click "OK" to save your settings.
  • Check your volume icon to make sure it does not have a red-and-white mute button around it.
  • Move the mouse click to the volume icon, then right click the mouse. Click on the "Open Volume Control" option on the pop-up menu. Remove the check on the mute button under the master control, if it is checked.
  • Move the volume slider in the master category upward. If you begin to hear sound, then the problem has been resolved.
  • Click the "Start" button on your screen, then click the "Run" option to check your Windows audio service. In the run window, type "services.msc" then click "OK."
  • Scroll down the list in the services window, then right click the "Windows audio option." Click on "Properties."
  • Select the "Automatic" option under the "Startup" tab, then click "OK." Test the sound. Try using headphones into the phone jack to test the sound
  • Click the "Start" button, then select the "control Panel" to check sound drives. Double click on "Sound and Audio" devices, then click the "Audio" tab.
  • Check the correct sound default device on your laptop under the "Sound Playback" option. If you installed other volume drivers on the laptop and you don't know the correct default, consult your user manual or contact the manufacturer.
  • Click the "OK" button ,i hope you"ll find this helpful,remember to leave your by saying how helpful this post is
  • Posted on Oct 07, 2010
    • Anonymous Oct 07, 2010
    • INSTRUCTIONAL STEPS
    • Move
    • Click
      click "OK."
    • Select
      the sound. Try using headphones into the phone jack to test the sound.
    • Click
      the "Start" button, then select the "Control Panel" to check sound
      "Audio" tab.
    • Check
    Ryobi 725r trimmer carburetor adjustment
    Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
    Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
    Mar 11, 2017 | Ryobi Garden
    Sniper ghost warrior 2 low sound volume
    from the beginning its perfectly work but after that sounds are not coming in any stage if any 1 can pls help me to fix this
    Dec 18, 2013 | City Interactive Computers & Internet
    The volume on my acer aspire 6530 is to low although the control
    if you have external speakers, try adjusting the volume there!
    If you don't, then click on 281bf5a1-868f-4ef8-aedd-d25642705e45.png icon, click 'Mixer', adjust the levels.
    Or click on Start, write in "Sound",4b2d9ebd-91e4-43cf-8490-3de18c6bc30c.png
    Adjust the settings for device/s you use to hear sound.
    Dec 18, 2013 | Acer Aspire 6530-5143 Notebook PC
    Low sound output from speaker
    Hi tabrezansari,
    I have an aspire acer 4741 series laptop. I always turn my sound volume to the max (Fn key's + arrow UP).
    But if you encounter too low sound, you double click on the speaker icon in the lower right hand, it should bring up the mixer volume menu. Make sure none of the 'mute' buttons are selected. Also check the sliders to full volume or whatever is confortable for you.
    Hope it helps.
    Thank You for using Fixya.
    Sep 06, 2011 | Acer Aspire One PC Notebook
    My acer aspire 4741 lan driver was not to be found at acer web site ..how can i connect my lan network
    I found this driver for Acer Aspire 4741 for wireless LAN, see if it helps you. The link is below:
    https://www.yousendit.com/download/MzZIS3doZEtqY3J2Wmc9PQ
    Please note you have 7 days to download this before the download link expires.
    Feb 05, 2011 | Computers & Internet
    I have an acer 4741 laptop and my wifi will not connect
    It should connect. How are you trying to connect it
    Oct 20, 2010 | Acer Computers & Internet
    I hav acer aspire 4741 model laptop every thing is ok but im not satisfied with the sound,as i watch movie the sound is really low,but as i listen mucic the sound is bitter higher than the movie.Plz give...
    Your music-player software and your movie-player software have independent sound-level controls; just increase the sound-level when watching the movie.
    Aug 22, 2010 | Computers & Internet
    The delta universal miter saw stand will not adjust to level posi
    Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
    If this doesn’t work for you, please write back. Thanks,
    Nov 27, 2008 | Saws
    Sound output
    This comes under business class range.Note books in this range will be low in sound and multimedia
    Nov 01, 2008 | Computers & Internet
    Computers & Internet Logo
    265 people viewed this question
    David Payne
    David Payne
