Looking for manual j cooling and heating form for manual calculation
  • 43,501 Answers
I believe that you can download it here...
http://www.filecatch.com/?q=manual+j+residential+load+calculation
heatman101
Posted on Oct 07, 2010
Testimonial: "appreciate the timely response- you were dead on- thanx"
How to set timer on air conditioner us08d10c
Have Question
Freidrich, on the above page, has a question form at the bottom of its page. Manuals apparently can be downloaded via the main webpage but I am having difficulty identifying your airconditioner model in a way that permits locating a manual. Inquire about a manual via their question form supplying what identifiers you have.
Aug 22, 2017 | Heating & Cooling
Large Ice Build up on top inside back of fridge unit.
Could be the auto-defrost has stopped working. Most modern frost-free fridges have a heating element behind the liner where the cooling element is and the ice forms. Between the thermostat controlled periods of cooling the heating element should switch on for a short time to melt any ice that has formed and the resulting water forms into droplets that roll down the fridge liner until it is channelled into a drain leading to a tray mounted on the electric motor. The warmth from the motor evaporates the water and completes the maintenance-free frost-free system.
Possibilities are faulty wiring/connections, defrost timer, defrost element.
The defrost timer could be integral with the thermostat.
Some older fridges had a manual switch to start the defrost process.
Jun 30, 2016 | Refrigerators
Hp 32sII enter degrees minutes seconds
According to the "HP 32SII RPN Scientific Calculator Owner's Manual" (at the link below), you just need to treat degrees, minutes, and seconds conversions as hours, minutes, and seconds. Use the left-shift and right-shift keys together with the 5 key to convert to decimal-fraction form (D.d format) and to minutes-seconds form (DD.MMSSss), respectively.
http://www.hp.com/ctg/Manual/bpia5305.pdf
See pages 4-9 and 4-10.
hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-0.jpg hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-1.jpg
Apr 09, 2014 | HP 32sII Calculator
LAMBDA values form calculator
I am afraid nobody can tell you if your calculator can find eigenvalues because you do not identify its model. I suggest you read the manual. Casio calculator manuals are available here
http://support.casio.com/en/manual/manuallist.php?cid=004
Nov 07, 2013 | Casio Office Equipment & Supplies
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
Change decimals to radical form?
hi emily, most scientific calculators have a feature to switch between deg-rad-grad. lookout for a switch DRG or so on the keypad, this feature might also be activated via a "second function" operation. check out your user manual for further in depth help.
May 23, 2012 | Casio FX-300MS Calculator
Dividing fractions are not calculating correctly, I have to manually get the answer I need
Press the S--D key located above the DEL key to convert between symbolic and decimal forms. To have all answers come out in decimal form, press SHIFT MODE 2 to switch to LineIO mode.
Dec 13, 2010 | Casio FX-115ES Scientific Calculator
How to change polar form to rectangular form by calculator?
Use the Rec function (shift of the - key).
Rec(r,t) converts a polar value of magnitude r and angle t in the current angular mode. The real value is assigned to X and the imaginary value is assigned to Y.
Use the Pol function (shift of the + key) for the reverse.
It's on page E-37 of the manual. If you've misplaced your manual, you can download a new one from http://www.casio.com/support/manuals
May 28, 2010 | Casio FX-115ES Scientific Calculator
Fractions
I checked the manual for the EL-501W calculator and I found out that it does not do fraction calculations. However yours may be able to. Look for a key labeled [a b/c] and a [2ndF] key [d/c].
If you have them then you can calculate with fractions.
The way to use the [a b/c] key is as follows
15 [a b/c] 7 [a b/c] 19 [a b/c] should allow you to enter 15 and 7/19.
A mixed fraction can be converted into an improper fraction by pressing [2ndF][d/c]
Jan 08, 2009 | Sharp EL-501WBBL Calculator
Heating & Cooling Logo
386 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
