I have a Kenmore Model number 20852 washing machine. The motor runs and the water drains but it will not spin. Any suggestions?
  • 5,911 Answers
You may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers (such as your Kenmore) use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Posted on Oct 07, 2010
Our Kenmore top load model 22422 started having problems with the spin cycle. Once it gets to the spin cycle, it makes a terrible grinding like noise - it is not spinning. However it will drain if you let...
The double shaft motor does double duty. One direction for wash and another direction for spin. In wash mode the water stays put in the tub because the pump is running backwards. In spin mode the motors turns in opposite direction. This pumps the water out and spins the clothes dry. From what you have described the drive coupler is toast.
This video shows how to swap the drive couple out:
More HERE
Mar 01, 2011 | Kenmore 22422 Top Load Washer
Kenmore top load hqavy duty 80 series model 82980120 - how does one get to the drive belt. Washer motor hums but no action any cycle.
Your complete model number including the first 3 numbers , is needed to help you get to the coupling . The coupling , is the piece ( pt # 285753 ) which connects the motor to the transmission . When this piece breaks , the motor will run , but no machine action , except for water drain . Even spin , will not work , yet , you will hear the motor running .
Oct 11, 2009 | Kenmore 24032\24036 Top Load Washer
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore wont agitate or spin
The motor has a temperature cutoff. When the motor gets hot it switches off and won't go again till it cools. But something is causing the motor to overheat. Some overload.
Jul 25, 2008 | Washing Machines
Spin water from clothes
i also have a kenmore model # 110.23832100. It drains the water but does not spin leaving the clothes soaked.
Jul 07, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
