Related Tags:
This problem should be removed because:
Problem with Samsung LE32R41BD 32 in. HDTV-Ready LCD Television
Programming of cable tv channels on SAMSUNG LCD TV
I have tried many times programming the cable tv channels for my Samsung LCD tv. I followed closely all the instructions from the manual but the reception and sound is hazy. I used the same antenna for my old TV and I'm sure its working well because I tested the antenna on another
TV and it gives clear signals. Why can't the new Samsung LCD get the signals well? Something wrong with the TV? HELP! I can't even get a clear reception from our local TV channels!
Suggested Solution (3)
My LC46D64U just started doung the same thing for any over the air channel that starts with 6. It cuts out for a few seconds about every 60 seconds. Has anyone found a solution for this?
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Source: can't get all digital channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Source: programming channels
setup 32 inch sansui for digital reception
Our tv has digital format included but we are having trouble getting our local channels to come in. How do we scan for digital setup?
One channel on LCD not clear picture help!
LCD t.v just brought all channels tuned in great except one but on our old t.v all channels were perfect this one is in bedroom our plasma...
The digital programming here and I can't get...
The day digital programming came in I got several channels clearly. Since that day, June 12, I can't get any channels clearly. If...
when i am scanning for digital reception of local
when i am scanning for digital reception of local channels i can receive a few. there are other channels that i caught before the big switch...
canceled cable and want to tune into local
canceled cable and want to tune into local channels..but only get blank screen or "no signal". bought an antenna...still nothing
Tips for Helping wazzup88 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
CAN NOT RETUNE TVCAN YOU TELL ME HOW
I HAVE NO CHANNELS AT ALL CAN YOU HELP
my samsung le37m flashes once verticle band of...
when you turn it on it does not make any noise just flashes for a split second vertically colours then it will not do...
i moved house on tues my tv signal was ok tried...
i moved house on tues my tv signal was ok tried connect my samsung freeview tv gettin disply on screen weak or no tv...
LE32S73BD 32'' lcd switches on for 3 sec...
hi, recently my samsung LE32S73BD 32'' lcd has gone wrong. When switched on it just shows the screen for...
See all Samsung LE32R41BD 32 in. HDTV-Ready LCD Television Problems
Related Topics
Fix-O-Meter
64
64 people viewed this problem
- 0 people are following this problem. Be the first!
Top Samsung Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
