Question about Moen Home
Moen shower only. the guts are leaking. Has 12009 china printed on the side of the valve body. I pulled the guts out of the the body and found a rip in the side rubber gasket. Can I just replace the guts? And who has it. Not Lowes. Thanks, Fred
  • 14 Answers
SOURCE: moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Posted on Dec 27, 2008
  • 148 Answers
SOURCE: replace new moen 1200 stem, still leaks due to scratches housing
The proper fix for this is to hone out the scratches
take steel wool and wrap it around a dowel or piece of wood or ust stuff it into the housing and turn back and forth to smoth out the scratch
if the scratch is real dep you wll have to go to harbor freight and get a honing tol that fits on the end of a drill
the stem should have some type of crown washer that you should be able to get an assortment from lowes , ace or hd
If you are asing for a recommendation for a good silicone I always use GE silicone it is the best
as a last resort (if nothing else works to stop leak
I would take cartridge wall and streatch teflon tape as tight and smooth as possible to block water coming up between housing and
cartrideg this is not recomended by mfg just a spa (my initials) certified suggestion
Good luck
Posted on Jan 07, 2009
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
SOURCE: I have a Moen shower tub single handle from the
I took the parts to the Menards in town. Luckily I found the guy that knows it all! He showed me the rubber gasket( that holds the ball) to purchase as well as recommended that the 2 small rubber gaskets that were in there to be replaced as well while I had it open to avoid doing this in the future. I got home and replaced them and no leaks:) Thanks:)
Posted on Aug 30, 2009
heatman101
  • 43501 Answers
SOURCE: replace the cartridge for a moen shower
It is stuck, they come out very hard and a puller is made to make removal easier.
Posted on Nov 12, 2009
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
The moen shower pullout type hot/cold valve will not slide out of the main valve body even after the retainer clip has been removed. I found some corrosion on the retainer clip and I have sprayed the area...
Howdy, those can be like pulling teeth. The wd40 will not help that much as it is not a robust solvent. I suggest letting some liquid wrench sit overnight on it and then pulling real hard. Good luck:)
Regards,Farmerbear
Aug 31, 2010 | Moen Home
No pressure.. Help
cartridge # 1222,i am not aware of the # for the puller, i just asked for a moen puller.be sure to get one that pull's pos'i cartridge's. because the older type puller will not pull positemp easy.and while you have cart out run water to flush valve body out.good luck!
Feb 01, 2010 | Moen 2352 Chrome Chateau Single Handle...
I have a single handle Moen faucet in my shower. It has not been used for a while , now that my kids are home and try to take a shower there is little hot water coming from the shower. The cold water...
probable that there is mineral deposit's,scale buildup,inside. pull cartridge and look in valve body,turn water on to it and flush valve body real good.possible model #1222-if it's posi temp ,#1225 for reg faucet
Jan 01, 2010 | Moen & One Handle Tub & Shower Faucet
My moen model 3175 is leaking. What is the likely cause and how do I repair?
The cartridge is absolutely the culprit. Very good shower valve, however the cartridges do go. Shut the water, take the handle off, disassemble the face plate, remove chrome collar from body, remove retention split spring, pull cartridge itself straight out. Replace new cartridge in reverse order of removal. Cartridge can be found at home depot, or any plumbing supply store. Good Luck,
Steven
Oct 10, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Decreased water flow from Moen shower faucet
I would bet it's not the faucet at all, it's the showerhead. Remove it and look inside the hole, there is probably sediment built up in there.
Just clean it out and reinstall.
Please rate if this helps-
Mar 28, 2009 | Moen Plumbing
Old Moen Valve Body
take a mesurement of tap head across then go to local hardware store and have a look around it might be better to change hole set . thank you for useing fixya please rate me
Feb 23, 2009 | Moen 2919 Chateau Two Handle Tub and...
Shower head leaks water when water is turned on
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
308 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
