Question about Samsung RFG297AAWP (285 cu ft) Side by Side Bottom Freezer French Door Refrigerator
I have an error message on my screen that reads 0F (f degrees) on the freezer side and same thing on refrigerator side, what does that mean
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
SOURCE: refrigerator not cooling
Open the panel in the freezer, and take a hair dryer to the frozen coil.
Posted on May 13, 2008
22yooper
  • 828 Answers
SOURCE: refrigerator side not cooling - freezer side icing up
It sounds like your defrost system has failed. There is a timing device that turns on the defrost heater(s) which may have stopped working. Or the heaters or defrost thermostat could be bad.
My suggestion is to find a different repair person who is qualified.
Posted on May 30, 2008
SOURCE: I have a side by
If the blinking continues, you may need to “reset” the Refrigerator. Try unplugging the appliance, wait for
around 10 minutes and then plug the power cord back in.
Posted on Aug 07, 2008
I have a GE Profile side by side refrigerator. It has not been cooling very well, it stays between 38-41 degrees. also the ice maker doesn't make a lot of ice and the cubes are smaller in size.
Ice maker want work if freezer bus not around 0F. Are fans running? Is condenser coils clean? Is there any frost build up on inside back freezer wall?
Nov 06, 2017 | GE Refrigerators
My double door galaxy (5 year old or so) seems to be at the right temperatures but the control reads 56 degrees for the freezer and fridge
Get a thermometer for both fridge and freezer to ensure temps are correct. Freezer should be around 0F and fridge around 37-38. If temps are correct but display is reading that much differently, control is most likely bad.
Sep 08, 2017 | Galaxy Refrigerators
Samsung rs267tdrs panel displays 0F for both fridge and freezer
Here's a link to answer what the OF meaning is for your refrigerator.
Error Codes Messages Blinking
Jul 26, 2016 | Samsung Refrigerators
My refrigerator rsg307 says on screen 0f 0f. what does that mean?
Of Of means it is in demo mode
Push energy saver and freezer button at the same time for 3 seconds....
Apr 21, 2013 | Samsung RSG307AARS Stainless Steel Side by...
What does code 0F mean? Freezer and Frig both quit working, can you help?
Sounds like it is in display mode. It will go into display mode by pressing the lighting and freezer buttons for 3 seconds. Hold both down for another 3-5 seconds and it will start cooling.
Dec 21, 2011 | Samsung RS267TD
On our Samsung RS267 and 25.5 cu ft refrigerator, we have an "OF" light on both temperature readouts (freezer and refrig.). What does this mean and how can the problem be rectify so that we will...
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
here is a video explaining (for all models) what is to do ..
http://www.samsung.com/us/support/owners/topic/RSG257AARS/XAA
Aug 15, 2011 | Refrigerators
I have a GE Profile Side by Side Model PSS26PSS2C that will only cool to 44 degrees. Any recommedations as to a solution?
If the freezer temperature is okay, you might want to check the damper control. The airflow from the freezer might be blocked. Now, if the freezer temp is not where it's supposed to be (0F-10F degrees), then you need to check the cold control or there may be an issue with the defrost system.
http://www.appliancepartspros.com/
Feb 09, 2011 | GE Refrigerators
Food gets spoiled too soon
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Apr 30, 2008 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Samsung RFG297AAWP (285 cu ft) Side by Side Bottom Freezer French Door Refrigerator Logo
201 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
