Question about AudioCodes MP-112R/2FXS/3AC/SIP-3/UC ANALOG VOIP GATEWAY [mp-112r2fxs3acsip3] Router
Ip default audio codes mp-112R - AudioCodes MP-112R/2FXS/3AC/SIP-3/UC ANALOG VOIP GATEWAY [mp-112r2fxs3acsip3] Router
2 Suggested Answers
dante777
  • 623 Answers
SOURCE: AudioCodes MP-11R/2FXS
The easiest way (if enabled) is to use the voice menu as if you would assign a new IP to the device.
  1. Connect a telephone to one of the FXS ports. Lift the handset and dial ***12345 (three stars followed by the digits 1, 2, 3, 4, 5).
  2. Wait for the 'configuration menu' voice prompt to be played.
  3. To change the IP address, press 1 followed by the pound key (#).
  • The current IP address of the gateway is played. Press # to change it or hang up if you don't want to change it.
  • Dial the new IP address; use the star (*) key instead of dots ("."), e.g., 192*168*0*4 and press # to finish.
  • Review the new IP address, and press 1 to save it.
Of course you can try the default IP of 10.1.10.10 if the device is set to it's default standards.
If not, you can try a network scanner like angryip (link) or network scanner (link) - this might take a long time, since the IP can be virtually anything.
If you have physical access to the device, you can also use a straight RS-232 cable to connect the AudioCodes to your PC and use HyperTerminal to connect (Baud Rate: 115,200 bps (MP-124), 9,600 bps (MP-11x), Data bits: 8, Parity: None, Stop bits: 1, Flow control: None)
If you need the manual (and it never hurts ;-) here is the link:
http://www.audiocodes.com/filehandler.ashx?fileid=36320
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 23, 2009
I have a wireless G broadband router. I've had it for quite some time and i dont know where the pin code is or the disk the router came with. how do i find the pin code without the two?
The pin code is normally found on the label on the bottom of your router but it's not mandatory to use it. You can reset your router back to factory and google it's default ip address and it's default password depending upon your brand of router. I would search for D-Link Router default password, default username, and default IP address. On a D-Link router the default IP address would be 192.168.0.1 The default username: admin The default password: leave the password box blank.
Sep 06, 2011 | Computers & Internet
Tip
CANON MP 145 OR EQUILENT SERIES PRINTER
CANON MP SERIES PRINTER PRODUCE BEST QUALITY OF PHOTO PRINTS WITH REFFILLED. ALL SPARE PARTS AVAILABLE IN CANON IP 1300 WHICH IS AVAILABLE IN LOW COST. (PURCHASE IP 1300 ONLY FOR SPARES - CARTIRIDGE CL-41 THAT PROVIDE MUCH HIGHER PRINTS, & COMMON SPARE PARTS MATCH WITH MP SERIES PRINTERS.) EXCHANGE THESE & EARN MORE. PLS VOTE & REPLY priyankaanta@yahoo.co.in
on Jul 26, 2010 | Office Equipment & Supplies
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
How do I change default scan settings on MP161
you can remote into it by a web browser and ip address then log in as admin and no password.
Mar 18, 2010 | Ricoh Aficio MP 161 Black and White Copier
Need to reset to factory settings due to assigned IP address is no longer working
Unplug the network cable and hold in the RESET button (small hole on back of unit) with a paperclip for 6 - 10 seconds. The default IP is 10.1.10.10.
Feb 16, 2010 | AudioCodes MediaPack MP-114 FXS
How can i configure audio code?
In the fast track guide there will be IP's listed. find the one for the device you are configuring, set you computer or laptop to an IP that is in the same range and connect via your broswer by IP.
Example:
Audio Codes IP and mask: 10.1.10.10 255.255.0.0
Set your pc IP to: 10.1.10.11 255.255.0.0
In the address bar of your browser type in 10.1.10.10. You should get a window asking for user name and password.
Nov 25, 2009 | AudioCodes MediaPack MP-114 FXS
Oct 22, 2009 | AudioCodes MP-112R/2FXS/3AC/SIP-3/UC...
Way to reset mp-114 audio code to factory settings and configure
Unplug the network cable and hold in the RESET button (small hole on back of unit) with a paperclip for 6 - 10 seconds. The default IP is 10.1.10.10 sm 255.255.0.0 if it is an FXS
10.1.10.11 sm 255.255.0.0 if it is an FXO
May 16, 2009 | AudioCodes MediaPack MP-114 FXS
Lost Default IP Settings screen after Mult. Interface Table
You have to do a factory reset to the device or it wont go away, make sure you dissconnect ethernet cable when doing the factory reset.
Jan 30, 2009 | AudioCodes MediaPack MP-114 FXS and FXO...
AudioCodes MP-112R/2FXS/3AC/SIP-3/UC ANALOG VOIP GATEWAY [mp-112r2fxs3acsip3] Router Logo
310 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
