Question about 2wire 2700HG-B Router (2700HGB)
The 2701hg-b is not sensing that I have connected my dell laptop. ethernet port on router is not lighting up when I make the connection. When I run cmd/ipconfig on my laptop it is blank. I've already restarted the router, what's next?
    President:
  • 1,768 Answers
1. the command you are using is incorrect it is : ipconfig /release >>> then ipconfig /renew
at the DOS prompt.
2. to get to the DOS prompt you will need to type "cmd" in the search field the hit enter
this will bring you to the DOS screen.
3. unplug the Ethernet cord for 30 seconds then reconnect it
4. go into the router via a browser window / in the address locator enter 192.168.0.1 this
should bring you to the routers GUI ( graphical user interface) then from there go to the
router status page and use the "helps" to lease/ renew the IP address assigned by the
router.
Posted on Oct 07, 2010
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
How do I hook up my 2wire router?
Run a 2-strand or 4-strand telephone-wire from your telephone wall-jack to the telephone-port on the router.
Run an 8-strand "straight-through" (not "cross-over") Ethernet cable from one of the 'LAN' ports on the router to the network port on your computer.
Connect the AC power to the router, and turn it on.
You now should have Internet access.
Or, telephone the Technical Support department of your Internet Service Provider, and get them to help you, step-by-step.
I am using the Dell Latitude D620, When i am connecting this machine on network I am getting 100 MBPS connectivity, but when i am connecting other machine to the same network port I am getting 1GBPS...
Hi Ajay,
The LAN (wired network) connectivity speed/data rate depends upon the networking hardware (Laptop Ethernet Cards, Switch, Router etc.).
To get 1Gbps connectivity you must have 1Gbps ethernet (LAN) card in the laptops. As Dell Latitude D620 has 1Gbps card, the problem could be with the switch or router, which may be having 100Mbps and 1Gbps ports, depending upon the equipment you are using and it is recommended that you check out the its full specification. If you connect laptop to 100Mbps port you can only get 100Mbps speed. To get full speed, it is required to have 1Gbps support at both ends.
Dont forget to rate the solution if it helps!!
CreativeTECH
Dec 03, 2010 | Dell Ethernet Card Network Adapter
Ethernet light is blinking wireless light is off
wireless light will litup only if a wireless connection is established with any devices....
make sure the wireless switch on your laptop is turned on and try...
Aug 11, 2010 | 2wire (2701HG-B) Wireless Router
Will a 2 wire dsl router 2701HG-S work with cable modem
No, not the way you want it to. The wan(internet) port on the 2701 is an rj-11 that will only connect to a phone line with DSL service. There is no way to use this as a router with your cable modem. You need a router that has an ethernet (rj45) port as the wan port.
Oct 05, 2009 | 2wire 2700HG-B Router (2700HGB)
2701HG-B lights went out and then power died
I've had good luck with that same 2wire router, but Att is right, the ethernet & internet lights should stay on. Have you tried moving the ethernet connector to a different port on the router? If they're going out, some component inside is failing, but it could be specific to that one port, and you may be able to use another without a problem. (Just a thought.)
You can contact 2wire support directly from here, if you choose.
And there's a full user's guide with some troubleshooting options and diagnostic tools available (to some subscribers) here.
But it sounds like it may be time for a new router...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | 2wire 2700HG-B Router (2700HGB)
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting my router
Ok, so the ethernet port on your DSL or Cable modem has to be connected to the WAN port on the router first and foremost. Then I would suggest that you connect the ethernet port on the laptop to port 1 on the router, and attempt to log in that way. Bring up your browser (Internet Exploder, Netscape, etc.) and type 192.168.1.1 (if that doesn't work try 192.168.0.1, Linksys switches it up) in the adress bar... and ensure that you can get in that way. Then try surfing the web to see if it connects correctly... although you may need to speak to your Internet Service Provider to ensure that they are allowing your MAC Address to connect to their Network... the one under the WAN settings, NOT the LAN settings. It should look like this... MAC Address: 00:01:81:52:3f:99
Sep 08, 2007 | Linksys Wireless-N WRT150N Router
2wire 2700HG-B Router (2700HGB) Logo
55 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
